started 94 gsr for the first time since nov , idle at 3000
Old Feb 19, 2004 | 12:51 AM
JBBNJ609's Avatar
Default started 94 gsr for the first time since nov , idle at 3000
i turned it off cuse it scared me , it was at the tranny shop and he says thats not right , there was smoke everywhere and smelled bad
how do i fix thing , 3 grand is too high on a cold engine and i worried help me out , thanks
JAY
Old Feb 19, 2004 | 08:28 AM
JBBNJ609's Avatar
Default Re: started 94 gsr for the first time since nov , idle at 3000 (jason bouchard)
bump
Old Feb 19, 2004 | 08:30 AM
96 Ls lnTeG's Avatar
Throttle Cable???
Old Feb 19, 2004 | 09:18 AM
iH8RICERZ's Avatar
smoke everywhere???? did you check your oil?
Old Feb 19, 2004 | 09:25 AM
ThePro's Avatar
Hrm. When I installed my GS-R engine it had sat for a little more than a year before it was started. I'd go through and change the oil and radiator fluid and then give it another shot.
If you are paranoid (like myself), then take out the sparkplugs and drivers side wheel. Make sure it is in neutral and get a LONG extension and just turn the crank. I forget which way to turn it, but if you turn it enough (and you can take off the valve cover to check) you will get the oil circulating back through the engine. Keep turning it for awhile to get everything relubed.
Or it could be something with one of the gaskets. When the gaskets sit long enough they dry out and turn hard. That could also be a problem.
Sorry I can't pin it down for you, but that's what I did. Turned the crank for a long time. My arms felt like jello after I was done. Taking out the spark plugs is key though. Don't want to work against compression.
Old Feb 20, 2004 | 12:06 PM
JBBNJ609's Avatar
Default NEW STUFF!!!!
ok , so i reset the ecu , and drove it around the block , when i first start it it just sits at like 3000 rpms , then i guess when it warms up more it startinggoing from 3000 or 2500 down to 1 then up then down and up and down again and again
it drives fine . . but i turned it off and tryed to start it again and it would just click once and die ( no power) so i had to jump start it , then it worked fine to atleast bring it back 1 block to the shop
my alarm isnt as loud as before the accident idk gimme info , i am searching on more then one forum so i just want lots of suggestions of things to try ( i really dont wanna have to spend more money though)
Modified by jason bouchard at 4:46 PM 2/20/2004
Old Feb 20, 2004 | 12:22 PM
WhoNeedsBoost's Avatar
As far as the alarm goes, check the horn, body shops usually stick a rag in there so when the alarm does go off its not in their ears.. atleast thats what i've noticed around here could be differnt there...
Old Feb 20, 2004 | 12:37 PM
JBBNJ609's Avatar
Default Re: started 94 gsr for the first time since nov , idle at 3000 (WhoNeedsBoost)
no horn at all , alarm uses a siren , no rags . . they only worked on it when i was there and i had the keys
Old Feb 20, 2004 | 12:44 PM
siren = horn. same thing..
Old Feb 20, 2004 | 12:46 PM
its plenty easy to stick a rag up there to absorb the sound when your working on a car...
JBBNJ609's Avatar
ok good job , but im tellling you , no , that didnt happen
Old Feb 20, 2004 | 12:50 PM
okay just checkin
Old Feb 20, 2004 | 12:53 PM
TegLove's Avatar
mine has been sitting since november too. I start mine up every sunday though and let her idle just so that nothing happens. Last winter I didnt start it for like 3 months and I had the same problem. I gave her a tune up and drove it for a few days then it was ok. Havent had a problem since.
Old Feb 20, 2004 | 01:15 PM
JBBNJ609's Avatar
Default Re: started 94 gsr for the first time since nov , idle at 3000 (TegLove)
What kind of tune up?
Old Feb 20, 2004 | 01:22 PM
TegLove's Avatar
just did an oil change new plugs and wires. And it was fine.
maybe check your timing too
Old Feb 20, 2004 | 01:32 PM
JBBNJ609's Avatar
You had the idle serge? and that fixed it?
Old Feb 20, 2004 | 01:34 PM
TegLove's Avatar
i had the idle bump up to about 2800-3000 and yea that fixed it. I dont know why. but it did.
Old Feb 20, 2004 | 02:24 PM
JBBNJ609's Avatar
hmm, thats weird , i have stock wires , but new plugs oil change every 2000 miles
Old Feb 20, 2004 | 02:47 PM
JBBNJ609's Avatar
what about the IACV or THE PCV valve or fast idle thermo valve ??
i am getting a small amount of smoke in the engine bay , all white smoke and the idle surges still
i let it still for a while runing to warm up , then the idle surges , the i drove it and it still surges in neutral and when the clutch pressed down( neutral)
please help ,im out of money and dont wann bring it to a shop ( that would be using alot of money)
Old Feb 20, 2004 | 06:14 PM
BEE18C1's Avatar
my car does the same thing, (95 GSR, revs real high then up and down FOREVER), I talked to some Acura techs at the dealership and they all told me to replace the Idle Control Valve, its attached to the Intake manifold and should take care of my prob and mayber yours, ill post here tommorow night to let you know how it goes.
Old Feb 20, 2004 | 08:33 PM
JBBNJ609's Avatar
Default Re: started 94 gsr for the first time since nov , idle at 3000 (BEE18C1)
ok kool, and can you maybe take pics and stuff on how to do it . . . thanks man
JAY
Old Feb 21, 2004 | 01:13 AM
JBBNJ609's Avatar
up
Old Feb 21, 2004 | 03:08 AM
GZR4DR's Avatar
IAC on the back of the manifold, bad gas, vacuum leak, air in the cooling system. If the cars been sitting a while, sometimes the hoses harden and will crack. IAC is self explanatory. They sometimes just go bad. Mentioned bad gas however I doubt thats your problem. Never really had a problem with gas unless the cars been sitting a really long time. Never know though.
Just a note, if your cars been sitting a really long time, unplug the distributor, and crack the motor a bit. Best to get the oil pumping through the engine before firing it up. Less risk of having no oil on the bearings and such. Then plug the distributor clip back in and fire it up. Good to go.
Old Feb 21, 2004 | 04:36 AM
JBBNJ609's Avatar
Default Re: started 94 gsr for the first time since nov , idle at 3000 (GZR4DR)
it was sitting since nov 2nd , so maybe the gas is bad , i dontknow how to take out the iac , i unplugged it , but it didnt make a diff at all
Old Feb 21, 2004 | 07:01 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
how to clean out your IACV:
http://www.g2ic.com/forums/sho...35534
Modified by MugenDude at 1:12 PM 2/21/2004
