radio makes a whiny noise everytime i turn on my headlights and when i accelerate???
they stole my radio and the fockers messed up all my wiring...so i wired up my new radio and it doesnt turn on.....the only way i can make the radio work is if i wire up the ignition wire to the power wire which results in the radio staying on even when the car is off...is this why my car has that nasty feedback noise?? everytime i turn on my lights its makes a buzzing sound and when i accelerate it does it even louder...sounds like im in a airplane.....any suggestions on what to do or whats causing this problem would be greatly appreciated
one check your main radio fuse...under the hood.. if that doesnt work.. grap a constant wire under the dash and wire it up to the deck..
whinny noise usually comes from band ground.. or your RCA are way to close to each other.. usually happends with cheap RCA
ok thanx alot ill make sure to do that and let u know what happens......thanx again for the info
you probably have a bad ground somewhere. What ur experiencing is called engine noise feedback.
Check your (-) battery terminal too. When mine gets corroded, I get a whining noise. Sounds like I have a big blower
djeclipzjv
12
Oct 11, 2015 11:38 AM
lakerschamp2000
Sep 5, 2007 04:23 PM
