Gauges Flicker on and off
Old Feb 18, 2004 | 07:43 PM
pbizzlegsr's Avatar
Default Gauges Flicker on and off
For the past week or so now..my aftermarket gauges that change from different blues to greens would flicker on and off randomly..its scary because i would be on the freeway at night and next thing you know it flickers and shuts off while i drive and i have no idea how fast im going..what can be the problem..i just changed the battery and it still occurs..can it be that a wire behind the gauges is not connect tight or is it my alternator? any help
Old Feb 18, 2004 | 08:45 PM
filthyCREX's Avatar
Default Re: Gauges Flicker on and off (pbizzlegsr)
it's probably just a ground. the connection is shorting out.. causing the flickering.
just check you connections for now, i dont think it's the alternator.
Old Feb 18, 2004 | 08:55 PM
pbizzlegsr's Avatar
Default Re: Gauges Flicker on and off (filthyCREX)
thanks
Old Feb 20, 2004 | 10:08 AM
filthyCREX's Avatar
did that fix it?
Old Feb 21, 2004 | 06:06 PM
Eric R's Avatar
Yeah, check for loose connections.
CaptivaEGezzer
Sep 4, 2010 08:22 PM
d15vtecivic
Jun 11, 2007 09:42 AM
stock4now
Jun 9, 2006 01:19 PM
hondaless
Jun 9, 2006 08:39 AM
m1rocs
Apr 8, 2006 01:44 PM
