Check Engine light. can't check it
Old Feb 18, 2004 | 05:39 PM
Bictorious's Avatar
Default Check Engine light. can't check it
I have a check engine light thats always on and i cant diagnost it cause there is something wrong. I tried to connect a wire with the 2 connectors holes to make it blink and give me a code but the light wont blink! anyone know whats the problem?
Old Feb 18, 2004 | 05:46 PM
B U N M A N G O's Avatar
Default Re: Check Engine light. can't check it (Bictorious)
Are you sure that you're jumpering the cable correctly? I just did this on my friend's Accord and the first time we did it, the light didn't blink because the paper clip wasn't connected properly.
Old Feb 19, 2004 | 11:03 AM
Bictorious's Avatar
ttt
Old Feb 19, 2004 | 12:02 PM
b16hybridsol's Avatar
bump, i've gotta friends car that doesn this, but the wiring under the hood is about ****
Old Feb 19, 2004 | 01:57 PM
didyouhearthat's Avatar
Well, my light doesn't blink, but I have a Crx.
Old Feb 19, 2004 | 02:04 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bictorious &raquo;</TD></TR><TR><TD CLASS="quote">I have a check engine light thats always on and i cant diagnost it cause there is something wrong. I tried to connect a wire with the 2 connectors holes to make it blink and give me a code but the light wont blink! anyone know whats the problem?</TD></TR></TABLE>
What year and model? Does it run? Have you checked the fuses?
Old Feb 19, 2004 | 02:24 PM
delslowh23's Avatar
Default Re: Check Engine light. can't check it (Chiovnidca)
I thought that meant the ecu
Old Feb 19, 2004 | 02:35 PM
evilhatch2.0's Avatar
Default Re: Check Engine light. can't check it (delslowh23)
that definitly means something under your hood is wrong. Do you have stock wiring??? stock motor??
Old Feb 19, 2004 | 03:59 PM
Bictorious's Avatar
Default Re: Check Engine light. can't check it (evilhatch2.0)
no, i have a b18b ls motor in a 95 civic coupe, swaped it about 9k miles ago and tis been like that ever since
Corruption
Jun 3, 2006 12:08 PM
VTECVillain
Jan 6, 2002 11:40 AM
