stock speaker size
Old Feb 18, 2004 | 04:41 PM
beaterman's Avatar
Default stock speaker size
does anyone know what the size of the stock speakers in the front doors, and rear pannels are. also does a 99 ls come with tweeters in the front or are the spots empty? thanks
Old Feb 18, 2004 | 04:42 PM
Xymox007's Avatar
Default Re: stock speaker size (beaterman)
http://www.crutchfield.com is your friend.
Old Feb 18, 2004 | 05:10 PM
95 integra's Avatar
Default Re: stock speaker size (Xymox007)
I think only the 00-01 LSs came with the tweets. 5.25" speakers fit in the factory holes, but the actual size is 6". Boston makes some that have an H after the model # specifically made for hondas.
Old Feb 18, 2004 | 05:19 PM
PhReSh N KleAn's Avatar
Default Re: stock speaker size (95 integra)
When I replaced my speakers in my 95 gsr I put in 6.5"s
Old Feb 18, 2004 | 07:51 PM
_blaze_'s Avatar
Default Re: stock speaker size (PhReSh N KleAn)
^^thats what i plan on doing.
Old Feb 18, 2004 | 07:57 PM
Erik_Pb_Foot's Avatar
New User
so 6.5" bolts up in the door without any problems?
what about the rear?
Old Feb 18, 2004 | 08:41 PM
FooSchnickens's Avatar
Default Re: stock speaker size (Erik_Pb_Foot)
prolly the same in fornt and back, could be wrong tho, may i reccomend the Jls? VR600 fits in my 89 teg, and so will the rest of the series. For the front (dunno if the later years have this) there may be some moisture cups that will keep the speaker from going all the way flush. Just make a hole in the back big enough for the magnet to stick through.
Old Feb 18, 2004 | 08:44 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I installed some cheap 6.5" speakers all around because my stocks were blown.
In the front I put in Pioneer 6.5's which directly replaced the stock (stock is Pioneer and the new ones even had the exact same basket design).
In the back I put in some 6.5" Jensen 2-ways. They fit fine, I just had to drill some new holes in the mount bracket to secure them.
Old Feb 18, 2004 | 08:49 PM
ajantics's Avatar
Default Re: stock speaker size (PatrickGSR94)
6.5 will fit no problem it's just the depth you need to check! =
Old Feb 19, 2004 | 12:40 AM
GotGSR's Avatar
Default Re: stock speaker size (ajantics)
the 6.5's wil mount up fine. You'll have to lose the stock honda baffle tho. Depth is another issue. The size of the magnets impact how deep the speaker sits. If your doing anything other than a shallow mount speaker, in the front you'll need a spacer. Just make one with high or medium density fiberboard, and do a cutout with a jigsaw. Took me twenty minutes.
DonDinero
Honda Civic (2001 - 2005)
Jan 10, 2008 10:54 PM
Bone Stock
Feb 3, 2006 07:43 AM
Ls InTeGrA RaCeR
Aug 29, 2004 07:40 AM
inzaneN1
Audio / Security / Video
Jun 25, 2003 09:57 PM
xevanx
Dec 3, 2001 10:58 AM
