Intake system = More gas usage?
yes and no...if you continue to drive like you drove before the intake you may get better mpg, but since most like to here the sound of the intake and take advantage of the added power you will driver harder and faster thus lower your mpg.
KGAccord is correct you will burn more gas because you will be using it a lot more to hear the intake but the extra air alone will not necisarily give you worse gass mileage either. I say it that way because more air taken in means more fuel needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord »</TD></TR><TR><TD CLASS="quote">yes and no...if you continue to drive like you drove before the intake you may get better mpg, but since most like to here the sound of the intake and take advantage of the added power you will driver harder and faster thus lower your mpg.
bowah..boy is that the truth..everyone wants to hear that made VTEC Yo..
</TD></TR></TABLE>bowah..boy is that the truth..everyone wants to hear that made VTEC Yo..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 »</TD></TR><TR><TD CLASS="quote">KGAccord is correct you will burn more gas because you will be using it a lot more to hear the intake but the extra air alone will not necisarily give you worse gass mileage either. I say it that way because more air taken in means more fuel needed.</TD></TR></TABLE>
actually in my car the more normal i drive the less mileage I get, the harder I gas it the better the mileage.
Oh yeah I forgot I can edit my own title! Yay!
Bingo. An intake alone won't do make that much of a difference. Hell, even a header won't. If you drive normally and don't drive like a maniac, you'll continue to get good gas mileage.
</TD></TR></TABLE>Bingo. An intake alone won't do make that much of a difference. Hell, even a header won't. If you drive normally and don't drive like a maniac, you'll continue to get good gas mileage.
96CXhatch
22
Sep 25, 2005 12:08 AM
blackriceman
Apr 7, 2005 07:34 PM
accord0494
Nov 8, 2004 10:07 AM
