ITB's what are the differnce?
Old Feb 18, 2004 | 02:04 PM
dwchkypmp20's Avatar
Default ITB's what are the differnce?
ok i know that this might come of wierd but it is for a good cause.......what are the differences between CBR 929 throttle bodies and gixxer 1000 throttle bodies.....i am about to buy some throttle bodies for my LS VTECed CRX and was wondering if these throttle bodies have a different diameter and what the pros and cons are for running honda ITBS vrs some suzukis? used search too
Old Feb 18, 2004 | 02:59 PM
Default Re: ITB's what are the differnce? (dwchkypmp20)
bump for a guy that needs help!
Old Feb 19, 2004 | 04:58 PM
JCushing's Avatar
im pretty sure the gsxr ones are 42 and hondas are 40, pretty sure
anyway you have to make a tps with the gsxr ones and the honda ones are supposed to use all the same sensors.
the honda ones look like they would be more difficult to work with imho
Old Feb 19, 2004 | 06:43 PM
Default Re: ITB's what are the differnce? (JCushing)
why would they be harder to work with if they use the same tps?,.....isnt that a plus?
Old Feb 20, 2004 | 05:48 AM
pro1342's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure the gsxr ones are 42 and hondas are 40, pretty sure
the honda ones look like they would be more difficult to work with imho</TD></TR></TABLE>
gsxr1000 = 43mm
cbr750rr = 38mm
cbr929rr = 40mm
cbr954rr = 42mm
CBR's use same TPS as the cars do.....
Old Feb 20, 2004 | 02:59 PM
JCushing's Avatar
the side that you would attatch an air filter too looks like its pre built up for an airbox. im just going on the physical setup of the tb's themselves.
Old Feb 20, 2004 | 04:55 PM
can we talk more about your itbs jcuching?....i am very interested......i am intrigued by itbs....are you running a diy set up?
Old Feb 21, 2004 | 05:32 AM
JCushing's Avatar
i dont have any
im planning on making a set but the pictures ive seen of the honda units look harder to work with than the gsxr ones
Old Feb 21, 2004 | 09:00 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">the side that you would attatch an air filter too looks like its pre built up for an airbox. im just going on the physical setup of the tb's themselves. </TD></TR></TABLE> easy to attach airhorns/funnels to that side because some mounting holes are there already
xparalandrax
Oct 28, 2007 08:31 AM
Ntense90crxsi
May 24, 2006 11:14 AM
Tonydalude
May 14, 2005 02:22 PM
an2ny888
Feb 4, 2004 01:51 PM
lilbill3554
Jan 28, 2004 07:39 PM
