****How hard to remove integra dash??
Old Feb 18, 2004 | 11:49 AM
dAng! Kris's Avatar
Default ****How hard to remove integra dash??
Im doing a interior swap if it isn't too much of a hassle to get the steering wheel and dash off. Can someone tell me how it is to be done? Thanks
Old Feb 18, 2004 | 11:58 AM
TeamSTEALTH GSR's Avatar
Default Re: ****How hard to remove integra dash?? (Frozty)
bump , anyone know a "how to" on 94+ integra dash removal. i searched, didnt find what i was looking for. help a brother out
Old Feb 18, 2004 | 12:37 PM
rusteds2k's Avatar
Default Re: ****How hard to remove integra dash?? (TeamSTEALTH GSR)
2 on the sides (by doors)
Behind the clock
Few behind the air control cosole (this is a bitch to get out safely) Make sure that you remember which path the cable came out of
I think that there is something underneath the airbar/glove box
1 under where the radio is
What I did when I removed mine, was take it a bolt at a time. Take what you see off, then start pulling (gently) then figure where it is still attached, find the bolt, and repeat. Remember to put all or at least most of the bolts back in or your dash will sound like **** later on.
Old Feb 18, 2004 | 05:16 PM
95 integra's Avatar
Default Re: ****How hard to remove integra dash?? (xaznxboixsirx)
There's also a bolt behind the sunroof switch. Taking the dash out isnt easy and I probably wont ever do it again unless something major goes wrong behind there.
Old Feb 18, 2004 | 05:18 PM
96AllMotorDC2's Avatar
Default Re: ****How hard to remove integra dash?? (95 integra)
i havnt done it in an integra, but i just did my crx. pain in the *** finding every little bolt and plug to disconnect. im just freakin glad im never putting it back in.
Pulling it out is the easy part, putting it back together...well..
good luck
Old Feb 18, 2004 | 05:36 PM
florduhdude's Avatar
Default Re: ****How hard to remove integra dash?? (96AllMotorDC2)
The 90-93 integra dash is pretty easy. If you have access to one at a junkyard where you have the run of the place, practice on one of theirs.
Old Feb 18, 2004 | 06:12 PM
Kendall's Avatar
Removing and replacing a dash is quite a pain in the ***, but if you have some measure of patients, you should be able to get it done.
Old Feb 18, 2004 | 06:22 PM
dAng! Kris's Avatar
Default Re: (Kendall)
hmmmm sounds like a interesting project, I wish there was a way to paint the tan interior so i didn't have to take it off, oh well i guess I'll start tomorrow sometime after school.
Thanks for the heads up guys
Old Feb 18, 2004 | 06:47 PM
aeon's Avatar
yeah its a bitch to change out the dash board. I did mines and that sucker took the whole day. I didn't put the wires in right so they wouldn't reach and if you can, have some one do it with you and also if you can take out hte steering wheel, it would help a lot. I had trouble pulling out the dash over the steering wheel but eventually i got it through. Also, i just got done painting some parts and the paint i used sucked so every little scratch would scratch off some paint.. so just search around for the right paint if you plan on painting some parts.
Old Feb 18, 2004 | 06:59 PM
Kendall's Avatar
Talk to jtintegra, he just recently swapped a tan interior for a black one so he may be able to help you.
Old Feb 18, 2004 | 07:11 PM
rtype11's Avatar
dont forget to swap your vin number back onto the dash, and if you get one with a VIN post it here many of us would like to hear the numbers.
Old Feb 18, 2004 | 07:58 PM
Erik_Pb_Foot's Avatar
New User
Default Re: ****How hard to remove integra dash?? (rtype11)
definatly a PITA but only b/c of the time it takes.
I loosened a few bolts on the streering column and just dropped it... didn't have to take off my wheel.
Old Feb 18, 2004 | 08:01 PM
tone*def's Avatar
Default Re: ****How hard to remove integra dash?? (Erik_Pb_Foot)
harder than a boner
Old Feb 18, 2004 | 08:08 PM
New User
Default Re: ****How hard to remove integra dash?? (tone*def)
hummmmmmmm
about that.... hahaha
btw... take out your center console and your front seats first.... dunno if that was mentioned but you'll have a hell of a time taking the dash out with that stuff in. and be sure you remove the glovebox and instrument cluster before getting too far into it....
Old Feb 19, 2004 | 12:28 PM
idrincwater's Avatar
a helms manual is your best friend in this project. it'll tell you step by step, with the location of all the screws, etc.
any of your buds got one laying around?
if you're local, i got one.
Old Feb 19, 2004 | 12:45 PM
dAng! Kris's Avatar
Default Re: ****How hard to remove integra dash?? (idrincwater)
i got a helm and some friends, thanks guys for all the advice, what was up with the VIN number thing?????????????
Old Feb 19, 2004 | 12:50 PM
integraL's Avatar
damn i feel sorry for you...usually when i take things off, they never go in the same way
radam
Dec 29, 2009 04:16 PM
sparcoboi77
Dec 20, 2008 12:05 AM
HybridGSR1
Jun 20, 2003 05:31 AM
bbmoto
May 22, 2002 12:13 AM
Coaster
Nov 30, 2001 11:53 PM
