Unreliable..HELP!!
Old Feb 18, 2004 | 11:32 AM
stjam27's Avatar
Default 94 Honda...Unreliable..HELP!!
I have a 94 accord, and slowly over the last couple of months the engine kills. It has gotten worse over time. Meaning it happens more frequently and wont start back up for a while. At frist it would start right back up. None of the battery related things turn off. The engine just dies and leaves me coasting. I thought it might be fuel related....so changed out the fuel filter and part of the fuel line....any suggestions...it wont make it to a shop so I have to get it towed and then diagnosed. Would really like it to work again. PLEASE???
Old Feb 18, 2004 | 11:40 AM
ForceThis!'s Avatar
Default Re: 94 Honda...Unreliable..HELP!! (stjam27)
when you try to start it back up, does it even turn over or is there nothing at all? When was the last time you changed your plugs and rotor? When was the last time you used injector cleaner?
Old Feb 18, 2004 | 11:41 AM
.bagged's Avatar
Maybe alternator..even though the electrical is still on that would come from the battery...just a guess but you might have to go to the shop
Old Feb 18, 2004 | 12:03 PM
The_Todd's Avatar
Farts in the shower
Default Re: 94 Honda...Unreliable..HELP!! (ForceThis!)
I know a notorious problem is the main relay for the older cars...if it just dies out but you still have power it might be this. PM a guy name RUBIZERK he sells them for way cheap. Good luck and welcome to h-t.
Old Feb 18, 2004 | 12:11 PM
ForceThis!'s Avatar
Default Re: 94 Honda...Unreliable..HELP!! (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">Maybe alternator</TD></TR></TABLE>
I was thinking that too
Old Feb 18, 2004 | 12:21 PM
.bagged's Avatar
Default Re: 94 Honda...Unreliable..HELP!! (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">I know a notorious problem is the main relay for the older cars... Good luck and welcome to h-t.</TD></TR></TABLE>
Main relay...I agree could be that too..
Old Feb 18, 2004 | 12:53 PM
stjam27's Avatar
I tried the rotor cables and plugs too. Just to start replacing the things that were easiest first...when I try to start it it cranks but doesnt turn over, but then I could go out an hour later and try to start it and it will start. Thanks for replying.
lrd27
Honda CR-V & Element
Aug 9, 2013 06:59 PM
dc2newb12
May 10, 2012 01:03 PM
JMalek
Nov 9, 2011 10:04 AM
94Accord2c
Oct 26, 2005 06:05 AM
rvanders37
Aug 3, 2005 10:51 AM
