Drivetrain ratio's??
Old Feb 18, 2004 | 10:16 AM
Duster's Avatar
Default Drivetrain ratio's??
I was wondering what the differnce is in drivetrain ratio's for example...
1st 4.35
2nd 2.50
3rd 1.66
4th 1.23
5th 1.00
as opposed to
1st 3.067
2nd 1.957
3rd 1.429
4th 1.125
5th 0.914
which of these transmissions is better geared for highway driving?? how can you tell?? lower ratio = lower revs?? sorry i am just trying to figure out which transmission would give me lower revs at higher speeds on the highway which will in turn increase my gas mileage on long trips...thanks guys!!
Old Feb 18, 2004 | 12:24 PM
Duster's Avatar
Default Re: Drivetrain ratio's?? (Mazdillac)
bump...someone ?? am i correct in assuming lower drive ratio = lower revs at higher speeds?
Old Feb 18, 2004 | 12:39 PM
JimBlake's Avatar
Those #s look like gear ratios, not overall drivetrain(?) ratios.
They're only part of the picture. Lower # means lower rpm at the same speed, IF the final drive ratio and & tires are the same. If the final drive isn't the same, you multiply the gear ratio (what you listed) X the FD ratio to get the overall ratio.
Say your 5th gear is 0.914 : 1 and your final drive is 4.10 : 1 then you multiply to get 3.75. That means for every revolution of the wheels, your engine makes 3.75 revolutions. Do your own homework about different size tires...
Old Feb 18, 2004 | 01:09 PM
Duster's Avatar
Default Re: Drivetrain ratio's?? (JimBlake)
wow, ok thanks...yeh those are gear ratio's...ok so that all makes sence, so having that information supplied for you on a website doesn't really help you at all in determining what RPM the car will be at at say 70 mph?? There is no real way to determine this unless you testdrive the car?
Old Feb 18, 2004 | 01:18 PM
JimBlake's Avatar
1) Some cars (kinda unusual) have a primary drive ratio.
2) Gear ratio.
3) Final drive ratio.
4) Tire size.
If you have all of this... you can do the math.
Old Feb 18, 2004 | 01:20 PM
Duster's Avatar
ok thanks alot
zakura R
Sep 10, 2015 07:42 PM
hamadiscool
Dec 20, 2010 04:46 AM
rodimus
Honda S2000
12
Jul 20, 2005 03:57 PM
MikeTV
May 14, 2003 10:15 AM
johng
38
Jun 26, 2002 06:00 PM
