OBD 0 injectors from a 90-91 ls integra in my OBD1 92 gsr???
hey guys whats up, I have a obd1 92 gsr with a b17a and a couple of my injectors were damaged. I was wondering if I would be able to use injectors from a 90-91 obd0 ls integra ?? any help is always appreciated. thanks alot guys
i'm currently doing the same thang.. b16a obd-0 in obd-1 hatc... and cut and solder on the b16 injector clips to run with my obd-1 harness.. My question is what is the resistor box.. and how do u wire it.. because i'm running really bad mpg about only 16 mpg..
You could find a resistor box from an OBD0 car, ie 89-91 Civic/CRX or 90-91 teg. Its not hard, there is one hot wire going into the box and 4 wires coming out of that would go to the injectors. Or, you could wire in the Radio Shack resistors inline at each injector.
surkitroller
Dec 29, 2009 12:58 PM
D.Dappa
Jan 18, 2005 06:56 AM
shauniewalnuts
Nov 22, 2004 07:15 PM
