Need some help please...
Old Feb 18, 2004 | 09:27 AM
h2392si's Avatar
Default Need some help please...
I was womdering if anyone know how to fix a code 67, a malfuctioning catalyst system. I wanted to know if anyone has had this code come on and how they went about fixing it. Its a 98 ex coupe, also does this code affect my vtec? Thanks for you feedback and peace out,
Old Feb 18, 2004 | 06:38 PM
bayarea13's Avatar
most likely you will need a new catalytic converter. if you can get youre hands on a gas analyser, do a cranking CO2 test. disable spark and crank the motor, should achieve 12% CO2 and if not youre catalyst is no good. only other things that could cause a catalyst inefficiency code are bad O2's or a bad PCM. very rare though, a bad O2 will usually throw another code and will prohibit the catalyst monitor from running.
Old Feb 18, 2004 | 08:52 PM
h2392si's Avatar
Default Re: (bayarea13)
thanks, wheres the PCM and does anyonelse have any ideas??
fast+forward
Oct 21, 2006 07:29 AM
mr. goodwrench
Dec 29, 2005 02:01 AM
::MUGEN::INTEGRA::RSi
Feb 11, 2005 08:19 AM
South sol
Nov 4, 2003 06:55 PM
