NOT boosting up to wastegate's spring, any ideas?
Old Feb 18, 2004 | 04:59 AM
RedStarGsr's Avatar
Default NOT boosting up to wastegate's spring, any ideas?
hey guys, im just trying to figure out why im not getting my full 7.5 wastegate's spring's psi. i guess i should be happy that its not creeping! Im only getting about 6 to 6.5psi in all gears exept 5th, im getting about 5.5. all charge piping is hooked and doesn't look like any leaks. i haven't had it tuned yet so could the fact that its running pig rich be a problem? ...or that im running a cat and a 2.3" exhaust? 3" this weekend (wahoo...mainly for test pipe)
i know i could probobly get an EBC and get it to exactly what i want but i see no point in spending a few hundred dollars on something that should be working in the first place, and for only a few psi. my ic size is 20x8x3 if that helps. im running 2.5" from tb to ic and 2.25 from ic to turbo. any suggestions?
and yes i know that last bend sucks (erg i guess first bend off turbo) im waiting on a new flange to mate to the turbo, anyone know where ican find one i can weld to?
Old Feb 18, 2004 | 05:25 AM
B17aTrbo's Avatar
New User
Default Re: NOT boosting up to wastegate's spring, any ideas? (RedStarGsr)
Doesn't the intercooler cause some loss in boost pressure?
Maybe a catalytic converter or something? I had about a 1lb. Pressure loss due to my cat, switched in a test pipe and found some boost...
Old Feb 18, 2004 | 05:41 AM
RedTegLS's Avatar
Default Re: NOT boosting up to wastegate's spring, any ideas? (B17aTrbo)
Why jump right to an EBC? Why not just get a $75 MBC like my TurboXS? I love it and it was literally a 3 min install! Wait till you get your 3" and see if that changes it for the better. I remember when I was getting boost creep someone said that the 3" exhuast allows the turbo to spool faster and that might have been causing the creep. So maybe when you go to the 3" it will boost right to 7.5psi?
Old Feb 18, 2004 | 06:59 AM
racerxadam's Avatar
where are you getting your boost source for the wastegate?
Old Feb 18, 2004 | 07:06 AM
b18bturbo's Avatar
Default Re: NOT boosting up to wastegate's spring, any ideas? (racerxadam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxadam &raquo;</TD></TR><TR><TD CLASS="quote">where are you getting your boost source for the wastegate?</TD></TR></TABLE>
are you running off the turbo or the intake mani
try a different vacuum source for the WG
Old Feb 18, 2004 | 05:33 PM
RedStarGsr's Avatar
everything is coming off of the back of the manifold, and im running a 2.5 carsound right now.
i hear mbc werent as dead on ***** accurate as an ebc and i need that with an unbuilt block and a130xxx miles . any other ideas? the exhaust will be done hopefully this weekend
Old Feb 18, 2004 | 06:04 PM
EG(6)SR's Avatar
bump for you!
I've got the same problem. My turbonetics wastegate is suppose to be adjustable from 6-9lbs.... The spring that is......and for some reason even at its highest setting it won't boost over 6 lbs.
At the track however, when I was running open downpipe it creeped up and held steady at 7 psi. I don't know if its the crappy wastegate, or exhaust leak, or unfunctional spring. I'm going to buy the 9-12psi spring pretty soon to see if that will change the problem. If that doesn't work....probably a new wastegate. Down the line when I'm outta school new turbo and new ebc/mbc depending on the price. Until then poor mans boost controller.
Old Feb 18, 2004 | 09:04 PM
RedStarGsr's Avatar
how much is the actual spring?
Old Feb 18, 2004 | 10:32 PM
mattcalica's Avatar
hey, i got the same problem...i had a leak in my fpr hose, could that be a reason that i couldnt boost over 5 psi? sorry to thread jack.
Old Feb 18, 2004 | 10:37 PM
MikeMAN's Avatar
are those rubber or silicon couplers? i wouldn't be suprised if there was a tear in one. (if they are rubber)
mike
Old Feb 18, 2004 | 10:46 PM
XSIintegra's Avatar
Default Re: NOT boosting up to wastegate's spring, any ideas? (MikeMAN)
A good friend of mine is in a big 240sx group out here in Arizona. He built a pressure tester with some pvc pipe and coupling found at any hardware store and used a old boost gauge he had. When hook up to the first pipe after to the turbo, he pressurizes the pipes to find leaks. You would be amazed at what has been found. Turned out his problem was a cracked ic core. Just an idea
Mr.E.G.
Apr 18, 2007 09:46 AM
turbotime
Apr 29, 2005 11:43 PM
delslow94
Oct 9, 2003 08:50 PM
DC2_Integra
Oct 10, 2002 02:58 AM
