"01 Accord fog light instalation
Hi all,
I'm trying to install a pair of Piaa fog light on my accord. On the relay it has a wire to connect to a power source. I want to connect that wire to the market light, so when I turn on the market light the fog light will be on. I open the market light connection, it has 3 wires. I don't know which wire should I connect to the relay wire. Any help is appreciated. Thanks
Hmmm wait a second. If I recall correctly, the "power source" should be your battery. The on/off switch the then has leads that plug into the fuse of which circuit you want it to be switched with, so when activated, the relay closes the circuit between your battery and the PIAAs.
Ugh it's been like 5 years since I did that.
