Resurfacing turbo manifold?
Old Feb 17, 2004 | 11:37 PM
Kwuaymaikrup's Avatar
Default Resurfacing turbo manifold?
I cannot get my manifold to seat properly to the head. I was wondering if the best way to cure this would be to resurface it? My flange is cut like this and there is no way the tiny manifold studs will straighten it out.
Has anyone else had this problem? If so how was it solved?
-Ryan
***Pics stolen from 0X64***
Old Feb 17, 2004 | 11:38 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Resurfacing turbo manifold? (Kwuaymaikrup)
You talking about the expansion slots?
Old Feb 17, 2004 | 11:40 PM
Default Re: Resurfacing turbo manifold? (Arturbo)
Yeah kinda, after it was cut it moved a bit and the flange is no longer flat.
Old Feb 18, 2004 | 03:42 AM
S2KP's Avatar
wow that looks warped
Old Feb 18, 2004 | 05:46 AM
Mase's Avatar
take it to any machine shop, theyll fix it for probably $15
Old Feb 18, 2004 | 05:55 AM
tony1's Avatar
Default Re: Resurfacing turbo manifold? (Mase)
usually you can just put it on. You'd be surprised what those studs will straighten out. When it gets hot it'll usually seal better and then you can retighten. I've had a couple like that and no problems. The slots let it move, so when you tighten it down it'll usually straighten out.
Old Feb 18, 2004 | 05:58 AM
PM-Performance's Avatar
Default Re: Resurfacing turbo manifold? (tony1)
mine was the same way , i got mine on and tight and no probs with it yet. when it heats up it should get better
Old Feb 18, 2004 | 06:06 AM
BoostedKrazi's Avatar
you should be able to put it on, get em hot, then be able to tighten some more.
Old Feb 18, 2004 | 08:51 AM
Bailhatch's Avatar
Default Re: (BoostedKrazi)
If you want it to last a while I would have it planed or at least go at it with a hand belt sander to get it close. I have a stainless manifold that was warped like that so I cut expansion slots in it (like yours) and sanded it flat. Seals great and no longer cracks. I had to take out about 2.5mm in some spots. that was pretty extreme but as long as it's close to flat the studs will pull it in a little. I just don't want my runners under tension so I did it this way.
looks like if you just took down runner 1 and 4 it would be close.
Old Feb 18, 2004 | 09:03 AM
dfoxengr's Avatar
heat it up, put on the head, and tighten that suka down.
then retighten after you run it for awhile.
Old Feb 18, 2004 | 09:04 AM
legendboy's Avatar
Default Re: (Bailhatch)
I had a similar problem with my manfiold, it will straighten out because its basically 4 little flanges that move. but I had mine resurfaced. it cost me alot because nobody could figure out how to mount it properly.
Old Feb 18, 2004 | 09:18 AM
Default Re: (legendboy)
Thanks guys...well i have mounted it but it is nowhere close. I mean more exhaust comes out between the flange than the DP...lol...I guess I have to tear her apart and machine it.
-Ryan
Old Feb 18, 2004 | 10:31 AM
Default Re: (Kwuaymaikrup)
talk to Cody about it , if it were me in that situation, id deff try to get it fixed or replaced for free. like i said i said something to him about mine, but he said it would be fine , i havent noticed a prob yet, but i havent driven the car much
Old Feb 18, 2004 | 11:11 AM
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">talk to Cody about it , if it were me in that situation, id deff try to get it fixed or replaced for free. like i said i said something to him about mine, but he said it would be fine , i havent noticed a prob yet, but i havent driven the car much </TD></TR></TABLE>
I will definatelly try that..thanks
Old Feb 18, 2004 | 10:47 PM
Are you guys using the stock bolts? Mine keep f*ckin stripping cause I have to use the open end of the wrench. I wish I would have went with a freaking log! This is getting rediculous.
-Ryan
Old Feb 19, 2004 | 04:59 AM
i tried to use the stock bolts, but no go on this manifold. i went to Honda and got all studs and just put the nuts on . it was still a big PITA, youll find out there is an order to tightening them or it wont go on well . i still cant get one in the hole above the dipstick tube . oh well .
Old Feb 19, 2004 | 05:19 AM
Tinker219's Avatar
ya, you have to use studs. I REALLLY need an FAQ on my site, along with bolt sizes...
Get the manifold on as best you can, start the car up, get it hot. WITHOUT BURNING YOURSELF, crank the nuts down as tight as possible w/out breaking anything(or rounding off the nuts). And this should do it. If you take the manifold back off, it will retain the shape that it was in under tension.
Old Feb 19, 2004 | 12:32 PM
Default Re: (Tinker219)
I guess I was unclear with my wording. I am using the factory studs and bolts. I got it back on so we will see. If it doesnt seal this time I guess I will have it resurfaced.
-Ryan
Old Feb 19, 2004 | 12:47 PM
BodyKits NW's Avatar
I have the same problem with my manifold. That is why I hate it when I gotta remove the damn thing. But ohh well.
Old Feb 19, 2004 | 12:57 PM
BoostedH23a1's Avatar
lol.... take it to a machine shop where they resurce heads or do valve jobs... they will put it on a big *** bench sander thing. thats the way to properly fix your problem...
Old Feb 19, 2004 | 01:15 PM
b18b1hmtlove's Avatar
ahh, this thread was very very very helpful. i was having the same problem ill try running the car and cranking the bolts down more.
Good thread
Old Feb 19, 2004 | 02:19 PM
@irborne's Avatar
is that a Tinker or a full-race manifold?
Old Feb 20, 2004 | 01:59 AM
Default Re: Resurfacing turbo manifold? (@irborne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @irborne &raquo;</TD></TR><TR><TD CLASS="quote">is that a Tinker or a full-race manifold?</TD></TR></TABLE>
The pictured manifold is a Full-Race but my manifold is a Lovefab.
Armaan
Welding / Fabrication
19
Jan 23, 2009 06:28 AM
400WHPITR
Jan 15, 2007 02:24 PM
Snail Tuning
Aug 24, 2005 10:50 AM
lkailburn
Jul 31, 2005 11:57 AM
aznxphreak
Nov 30, 2003 08:06 PM
