Exospeed Racing competition race engines: B, D and H series
Exospeed Race Engines:HT Special
Competition Race Engines by Exospeed Racing. Built by our in house race engine specialists. Each race block is designed to each racer’s needs.
From street performance to all out Full race setupsÂ…. We can help design a package for you.
Many different stages to choose from. Check to see if there is a setup that is perfect for your needs.
Note: Every part used is Top Quality Parts. We only use Honda Bearings and Honda oil pump, water pumps and gasket sets. You won't see non-honda bearings or aftermarket replacement parts on our Race Engines. All block packages require core.
Honda part# labels are available on request to ensure you are receiving top quality OEM parts.
All block packages come with the following:
1. New OEM Honda Bearings (each measured to spec, no UNIVERSAL bearings used here)
* Each bearing size is measured by precision tools to ensure the most accurate clearances. NO Plastigauge here.
2. New OEM HONDA VTEC Oil pump
3. New OEM Honda Water Pump
4. Micropolished crank
5. Bottom end Gasket kit
6. Bore, Hone, deck, hot tank, R&R rods(if neces)
7. Assembly of block
B-Series
Turbo B16/B18 race/street block $1645.00
1. Arias 81.5mm 10.6-12.2:1 pistons w/ rings (compression will depend on the head and block used)
B16A head-B16Block 8:1 or 9:1
B16A head-LS Block 9:1 or 10.1:1
GSR head-LS block 9.2:1 or 10.4:1
GSR head-GSR block 9:1 or 10.1:1
2. Stock rods
Turbo 83mm B16/B18 race/street block $ 2695.00
1. RS Machines Sleeving
2. Arias 84mm pistons w/ rings
B16A head-B16 block 8.3:1 or 9.3:1 83mm
B16A head-LS block 9.4:1 or 10.4:1 83mm
GSR head-LS block 9.5:1 or 10.7:1 83mm
GSR head-GSR block 9.4:1 or 10.5:1 83mm
3. Eagle Rods
Turbo 84mm 1.8L-B16 /2.0L race/street block $ 2695.00
B16A head-B16 block 8.2:1 or 9.5:1 84mm
B16A head-LS block 9.2:1 or 10.6:1 84mm
GSR head-LS block 9.2:1 or 10.9:1 84mm
GSR head-GSR block 9.2:1 or 10.8:1 84mm
3. Eagle Rods
Turbo Custom Bore / Custom Piston Race block $2845.00
2. Exospeed Race sleeves
3. Eagle Rods
4. Arias Pistons: custom bore, custom compression to your specs
For the D-series Fans out there
D16A6, D16Z6, D16Y8, D16Y7
Turbo D16 $1645.00
1. Arias pistons w/ rings
D16A6 setup: 8.5:1 75.5mm
D16Z6 setup: 9:1 75.5mm
D16Y7 setup: 9:1 75.5mm
D16Y8 Setup: 9.3:1 75.5mm
2. Stock rods
Turbo D16 w/ Eagle Rods $1965.00
Turbo D16 Street/Race block $2695.00
1. RS Machine sleeving
2. Eagle Rods
3. Arias Pistons w/ rings(see compression above)
Turbo D16 Race block $2845.00
1. RS Machine sleeving: your specified bore size
2. Eagle Rods
3. Arias Pistons w/ rings – Custom bore and compression size
H-series: consult us for specific compression choices
Our competition race blocks are High Quality precision built for the best performance possible. Not only do we build top notch engines, but we race them as well. So you will get technicians that can guide you to the proper setup you will need.
Our race engines are used in competition in the NHRA, IDRC, NDRA and Battle of the Import in the PRO and Street classes. Choose us for your race block needs.
Exospeed Racing Products “Honest work, done with Pride”
Modified by exospeedAMcrx at 12:56 AM 2/18/2004
B-Series
2. Stock rods
3. Eagle Rods
3. Eagle Rods
3. Eagle Rods
Turbo D16 $1645.00
2. Stock rods
2. Eagle Rods
2. Eagle Rods
do those prices include the block, Or does one have to be provided?
edit:
didn't see this:
"All block packages require core."
edit:
didn't see this:
shipping is about $45-60 depending on your location. we also do complete race engines. Head, block, manifold, headers, etc. all ready to install.
KIWI
35
Nov 29, 2011 10:35 PM
ExospeedAMcrx
Apr 30, 2011 11:11 PM
kornerk12
15
Feb 20, 2007 07:49 AM
ExospeedAMcrx
Jul 20, 2005 11:55 AM
to Exospeed - very helpful and knowledgeable
