H23 VTEC hmmm
Old Oct 10, 2001 | 08:41 PM
akkording's Avatar
New User
Default H23 VTEC hmmm
Ok guys how hard is it to run a H23 block on H22 head? Is there anything special you need to do? I was told the two block are identical and should just bolt right up. Now that was the exact words from a highly rated local speed shop. Thanks.
[Modified by akkording, 5:41 AM 10/11/2001]
Old Oct 10, 2001 | 09:47 PM
preludeChaos's Avatar
New User
Default Re: H23 VTEC hmmm (akkording)
Someone help this guy out!... Cuz I need to know too.
Old Oct 11, 2001 | 04:41 AM
akkording's Avatar
New User
Default Re: H23 VTEC hmmm (preludeChaos)
I had someone IM me and said that you need to drill out the oil lines.
Old Oct 11, 2001 | 06:39 AM
Honda318dx's Avatar
There is actually a lot you have to do, can' remember the whole list.. Basically need EVERYTHING from the top of a H22a1 motor, including ECU...
Old Oct 11, 2001 | 06:45 AM
akkording's Avatar
New User
Default Re: H23 VTEC hmmm (Honda318dx)
I have a H22 complete swap in my Accord already. I just need to replace my block since it's cracked.
Old Oct 11, 2001 | 07:24 AM
boomslang's Avatar
It is complicated. You need the entire head of an H22a, p13 ecu, and all of the timing belt gears on the lower part of the h23 block need to be changed out for h22 gears.
There is some machining of the coolant passages in the h23 block if you want to do it right.
With h23 pistons and an h22 head, I don't know what the compression ratio is. It might be pretty low.
Old Oct 11, 2001 | 07:49 AM
akkording's Avatar
New User
Default Re: H23 VTEC hmmm (Inlinefour)
I have all the H22 parts, I mean the engine is in my car working just fine until the block got cracked(dont' ask how). The CR on a stock H23 piston is lower but you will have more torque and VTEC will be bad ***. If I were to go with the H23 Block, I would rebuild it completely with higher CR pistons.
Old Oct 13, 2001 | 02:55 PM
New User
Taking all that into consideration. Would the popular opinion be to just do a full swap, rather then try to do all that crap? And then not even be confident it will work. Does anyone know anyone who has done it and is enjoying it w/o problems?
Old Oct 13, 2001 | 05:22 PM
F22PwrdS2k's Avatar
Accually your compression will be higher because now it is 9.8/1. It will end up being about 10.8/1 or 11/1
Old Oct 13, 2001 | 06:26 PM
akkording's Avatar
New User
Default Re: H23 VTEC hmmm (SIPreludeRcr)
I didn't know that H23 had higher CR than h22. I know it's been done before just need to know how cause I want a h23 VTEC bad. Thanks yall
Old Oct 14, 2001 | 05:53 AM
Deadly-Lude's Avatar
It should be pretty reliable since the prelude that races on speedvision has a h23 vtec in it.
Old Oct 14, 2001 | 05:59 AM
Big James's Avatar
New User
Default Re: H23 VTEC hmmm (Deadly-Lude)
So does Steph Papadakis in his new Civic.
Old Oct 14, 2001 | 09:22 AM
New User
Default Re: H23 VTEC hmmm (Big James)
Well... Do any of you know these guys personnally? How did they do it, how much dd it cost, etc.
Old Oct 14, 2001 | 09:48 AM
Import RP's Avatar
It would be cool to have an h23 VTEC, but if I were you, I would just do the swap and get the JDM h22. It sounds ALOT safer.
Old Oct 14, 2001 | 11:18 AM
akkording's Avatar
New User
Default Re: H23 VTEC hmmm (Pyrochaos38)
I need a short block, my 97 H22 heads are perfectly fine. JDM H22 isn't a huge difference compared to a USDM h22, but if you go JDM Type-S now that's what you call the McDaddy of all H22's. I have Type-S cams now and I was thinking about getting Type-S pistons if I get a great deal on a H22 short block. I'm thinking about sending the heads and intake manifold to get P&P while the engine is parted.
[Modified by akkording, 8:22 PM 10/14/2001]
Old Oct 15, 2001 | 05:30 AM
akkording's Avatar
New User
Who are Steph Papadakis sponsors? I might try E-mailing Steph myself.
Old Oct 15, 2001 | 08:46 PM
H23Lude's Avatar
New User
yes it can be done! I know a guy that just finished doing it in his 96 prelude Si. His timing belt broke and messed up the head so he decided to just swap in the H22 head on his H23 block. I think he spent over $3000 and he did all the work himself. Its running great and no major problems. But the only problem he is having now is it only redlines at 6500 and not 7500 so he's not getting the full potential of it. He is still trying to figure out whats wrong with it...
h23sol
Oct 15, 2008 11:29 AM
pkolaboy
Feb 19, 2008 06:37 PM
DLB1994
Sep 23, 2001 07:26 PM
DLB1994
Sep 23, 2001 05:07 PM
