using timing light on '88 Civic 1.5L hatchback?
Old Feb 17, 2004 | 07:00 PM
annointed's Avatar
Default using timing light on '88 Civic 1.5L hatchback?
I need to run my '88 Civic hatchback through emissions/inspection, and just got a basic timing light today (I had to change the distributor since buying the car to fix a drivability issue). It seems to run great, and gets 37 mpg, but I don't want to take any chances, so I would like to set the ignition timing using the timing light.
Any advice? Its snowing today, and I haven't even had a chance to look at the crank pully area for marks, etc, but I assume this should be straightforward. Also, what is proper advance at idle for this car?
Its a 1.5L '88 Civic, fuel injected, 4 speed manual.
Thanks,
Mark
polishedturd
May 8, 2008 06:51 PM
annointed
Feb 17, 2004 07:09 PM
david90
Nov 18, 2003 10:09 AM
94civicx
Mar 20, 2002 10:43 PM
Jimmy L
Aug 21, 2001 01:14 PM
