Window not rolling up straight
Old Feb 17, 2004 | 06:31 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Window not rolling up straight
In my 1990 accord, when i roll up the drivers side window, its leaves like a 1/4" gap between the window and the top of the door ( by the seat belt ).... its annoying as hell when driving. Is this something i can fix or do i have to buy/replace something to fix it? If i take the door panels off what do i have to do to fix it? how hard is it?
Old Feb 17, 2004 | 07:32 PM
jwogen1's Avatar
Default Re: Window not rolling up straight (92prelude)
does it just not go up all the way? im not all to familiar with 4th gens, but does your model have manual windows or not?
Old Feb 17, 2004 | 08:58 PM
blondeaccord's Avatar
Default Re: Window not rolling up straight (jwogen1)
I have this same problem. I have power windows. We have taked the door panels off several times. My problem seems to be the weather stripping. I think that I am going to have to go to the local honda dealer and spend an arm and a leg to fix it. Good luck with yours.
Old Feb 17, 2004 | 09:03 PM
The_Todd's Avatar
Farts in the shower
Default Re: Window not rolling up straight (blondeaccord)
Well generally a quick fix is to get some silicon lubricant (like wd40 but way better) and get a q-tip and run it along the window track. This should fix it and if it doesn't plan on removing the door panel and lubing up the actual window track. This sounds like a lot of work but it actually goes really fast. It generally a typical problem with the 4th gens. Hope this helps out.
8YourV8
Dec 13, 2010 10:09 AM
Silverdot
Jun 24, 2006 04:42 PM
CivicBoi
Jun 18, 2003 02:02 PM
RATEDR
May 23, 2002 06:39 AM
96 Accord Ex V6
Jan 11, 2002 02:19 PM
