T3/T40E 57 trim/.63 a/r turbo...MINT!
Old Feb 17, 2004 | 06:07 PM
BlueSi2k's Avatar
Default T3/T40E 57 trim/.63 a/r turbo...MINT!
I put about 500 miles on this turbo before i realized that the compressor oil seal was bad from the factory. I called up the place where I got it from and they told me to send it back for a free rebuild. I had bought a precision turbo in the meantime so now I need to get rid of this one. The turbo has a 57 trim wheel with a .63 a/r exhaust housing and a .50 a/r compressor housing and a stage 3 turbine wheel. The compressor housing is slightly polished as you can see in the pics. The turbine has a 5 bolt outlet. I upgraded to the watercooled center section and the 360 degree thrust bearing. Water cooling cost me an extra $50 and the 360 bearing an extra $75.
The company did not just replace the seal but did a full rebuild and i can take pics of the old bearings they gave me if you want. There is no shaft play and this thing is spotless...no rust at all. Looks like it came right off the shelf. Absolutely ZERO miles since rebuild.
I'm asking 550 shipped. I have lots of references.
Last but not least here's the pics...
Best way to reach me is PM on here. Thanks
Old Feb 17, 2004 | 08:45 PM
BlueSi2k's Avatar
Default Re: T3/T40E 57 trim/.63 a/r turbo...MINT! (BlueSi2k)
bump
Old Feb 18, 2004 | 05:55 AM
BlueSi2k's Avatar
up
Old Feb 18, 2004 | 07:00 PM
BlueSi2k's Avatar
damn since when does this forum move so fast...
Old Feb 18, 2004 | 07:15 PM
dunkd's Avatar
its 1/2 garrett 1/2 Turbonetics?
Old Feb 18, 2004 | 07:27 PM
BlueSi2k's Avatar
Default Re: (dunkd)
I guess the turbine housing is turbonetics...thats how I got it. Its basically the same thing.
gnd101
Apr 6, 2009 07:38 PM
Drew2o2
Aug 8, 2008 05:16 AM
reactiondc2
Oct 5, 2007 07:33 PM
.RTErnie
Jun 27, 2007 06:32 AM
Wo-Nelly
Jan 26, 2004 06:00 PM
