what psi should your tires be for daily driving?
40 psi, are you kidding? Cold tire pressure for the Prelude is 28 psi.
[Modified by Pyrochaos38, 8:03 PM 10/11/2001]
No, 40 psi is not ok, over-inflated tires lead to improper tire wear and more "wear and tear" on suspension components.. 28 psi is the recommended pressure..
If you really want to be sure, you will have a sticker located in the car regarding the proper tire psi for your particular vehicle.. it will be located either in the glove box or the drivers side door jam..
If the tire has a higher than stock max pressure rating, like say 44, then its fine at 40.
The tires that were on from the factory have a lower rating.
If you run 28 lbs in a tire designed for 44 lbs max, you'll have more drag, and outer tire wear.
40 should be fine.
40 should be fine.
32, 32, 32! Raise PSI, you will wear tires faster. Lower PSI, you will get bad gas miliage. If you're in need a traction, drop to about 20 PSI for your tires to stick well, yet remember to raise them back up...
The PSI that will work best changes depending on the type of tires, and the driving conditions. It should not be based on the rating given for the factory all-season tires.
Example: My Yokohama A520's have a max of 44 psi. They wear evenly at about 38. For best performance, 34 up front and 32 in the rear work well, since they have stiffer sidewalls than most. A tire that doesn't have as stiff a sidewall will need more air for the best performance.
My winter tires, on the other hand, have a maximum of 35 psi, and I only run 28.
The sticker in the doorjam only works for the OEM tires.
mine says max tirepressure is 60 psi, and theyre at 40 psi right now, before it was at 22 and man it was hard to turn the wheel
sporty240
23
Aug 25, 2005 06:25 AM
