HOw hard is it to install valve seals, valves?
Old Feb 17, 2004 | 07:34 AM
TeamCracka's Avatar
Default HOw hard is it to install valve seals, valves?
My head is fucked up and I feel that it is because I have 1 or more bad valve seals, and possibly because I've had a ticking bent valve since I got the motor last fall.
I was wondering, if I get a spring compressor tool, how difficult is it to replace these two things? I'm kinda questioning it because in the Helms they do valve lapping, and heat up the head on an electric stove and all this **** that I really dont want to do, I'd rather just buy a new B16 head for $300.
Thanks =D
Old Feb 17, 2004 | 08:51 AM
sci motorsports's Avatar
just get a valve job done $250 and take the machinist the seals. that was the cost of the last one and it was really bad with backcutting on the valves. any machinist will check it out and even fix most the problems if any
Old Feb 17, 2004 | 01:04 PM
d16nomore's Avatar
Default Re: HOw hard is it to install valve seals, valves? (TeamCracka)
The seals are no problem to replace. If you have a bent valve, your engine will sound like ****, like it is running on three cylinders. If that is the case, the valve guide is what should be changed. Yeah, heat the block and then drift it out with a hammer and punch. Do the same to reinstall.
For the first time, get a shop to do it and ask if you can watch...
Make sure they check the bore of the guide and spec it out with the diameter of the valve stem...
Old Feb 17, 2004 | 06:33 PM
TeamCracka's Avatar
Default Re: HOw hard is it to install valve seals, valves? (d16nomore)
THats what I thought, thanks for the replys guys.
I'm I'm going to spend $300+ on for someone to do it + the cost of valve seats, guides, seals, and valves, I might as well just buy a 99-00 head for like $350
Thanks!
KoRE
Apr 13, 2010 09:40 PM
f22beast
Jan 17, 2010 10:02 AM
VSBB6
Sep 11, 2005 11:07 AM
E46M3CB
Mar 8, 2004 08:54 AM
skribblah
Jun 30, 2003 08:10 PM
