Door hinge messed up (I searched)
Old Feb 17, 2004 | 06:53 AM
Eresuncabron's Avatar
Default Door hinge messed up (I searched)
OK I was drivin my friend around on a windy day. He opened the door and let it go.
the wind bent the door/hinge or something so that it doesn't seal correctly. it seems to be not closing far enough at the top. how do you think i could go about fixing it.
should i just try to twist it and make the top go in?
its winter time and it feels like the window is cracked open all the time
help is appreciated.
Old Feb 17, 2004 | 02:45 PM
subgeniusdude's Avatar
Default Re: Door hinge messed up (Eresuncabron)
You can loosen the door latch screws and move the latch in a little,that will close the door a little tighter.Other than that,I don't know.Anyone else?
Old Feb 17, 2004 | 03:16 PM
Well thanx. Unless posts are about a B18C5. you cant get any help
Old Feb 17, 2004 | 04:01 PM
4drEF's Avatar
Keyboard Humorist
I did that to a Dodge. Take a good look at where the hinges mount to the lower A-pillar of the car. On that Hodge, the hinges were perfect, but I bent the metal of the A-pillar. I never fixed it... too much work for a POS car. If I needed to fix it, the door would have had to have come off and probably the front fender as well. Then the metal of the A-pillar would have had to have been pulled out some how.
Maybe your door hinges bent and you got "lucky". Just et some new ones and put them on. There's only 4 screws and one pin (for the thing that keeps the door open) holding the door on. You "should" remove the front fender first, but you can do it without if you are super carefull or if you don't care about your paint too much. It will be another 4 screws to get the hinges off the door.
HTH.
Old Feb 20, 2004 | 09:58 AM
Default Re: Door hinge messed up (4drEF)
So u think that i could have bent the pillar and not the hinge? thats interesting i didn't even think about that i'll hafta check it out. thanx
Old Feb 20, 2004 | 10:05 AM
AgentJam's Avatar
you need a new frame it's probably bent...
Old Mar 1, 2004 | 12:53 PM
civichopeful's Avatar
Default Re: Door hinge messed up (AgentJam)
You probably bent the hinges. I just did that backing out of my driveway. I was moving my car and was backing down the driveway. When I hit the end I had a big pile of ice there which grabbed the bottom of the door and yanked it open. I opened so far that it bent the hinges out and crushed the driver side fender.
I had DX hinges in my garage and used those but the door doesn't close correctly. I found out that even though they look the same, the hinges vary model to model. They are about 30 bucks from Honda. Special Order.
Old Mar 1, 2004 | 02:12 PM
jedubz's Avatar
LOL Im scared for my doors
Old Mar 7, 2004 | 04:29 PM
Default Re: Door hinge messed up (jedubz)
Ok well it's not the hinge that is bent
when the *** hole flung the door open it cracked the welds holding the door together.
so i guess i need a new door
Old Mar 7, 2004 | 04:44 PM
AgentJam's Avatar
shoot man that sucks! Just wait untill you swap and get all the body work done, it should be fine till then. Let me check it out i may be able to weld it???
Vince
RealRaw
Sep 2, 2020 05:22 PM
Supradon
Nov 2, 2008 05:03 PM
chiggin
Honda Civic (2006 - 2015)
Aug 28, 2007 11:31 AM
ryanyo11
Jun 29, 2005 12:06 PM
braypunt
Apr 14, 2005 01:20 PM
