D series wiring harness into b16
Old Feb 17, 2004 | 06:29 AM
mongoliandonuts's Avatar
Default D series wiring harness into b16
I bought the JDM b16 and the wiring harness is backwards so i was told to take the old wiring harness and put it on the new engine but i have to put some o2 sensor or something directly to the ECU anyways i havent a clue what they are talking about with that sensor will someone please explain the steps.,
and another sense its going into a del sol they sent me the wrong shift linkage its too short so can i just weld it and make it longer would that work?
Old Feb 17, 2004 | 06:50 AM
Default Re: D series wiring harness into b16 (mongoliandonuts)
any ideas bought the wiring harness?
Old Feb 17, 2004 | 07:01 AM
FatBoy85's Avatar
you'll have to run the knock sensor. run the wire straight to the ecu pinout. if you bought a swap it should already be there. d-series didnt come with a knock sensor. it's pretty simple. it's on the back of the motor i believe. and your O2 sensor should be fine if it's a 4-wire.
Old Feb 17, 2004 | 07:14 AM
MikeNice's Avatar
They may be talking about VTEC. You have those wires straight to the ecu.
Old Feb 17, 2004 | 07:17 AM
MikeNice's Avatar
You shouldnt weld your shift linkage, they always break and you will be left on the side of the road somewhere. Buy the right ones, dont be cheap
Old Feb 17, 2004 | 07:18 AM
doublejz's Avatar
Default Re: D series wiring harness into b16 (MikeNice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatBoy85 &raquo;</TD></TR><TR><TD CLASS="quote">you'll have to run the knock sensor. run the wire straight to the ecu pinout. </TD></TR></TABLE>
is correct. The o2 sensor will be fine, you need to run a single wire from the ecu to the knock sensor. Everything else should be plug and play. If the engine you had didn't use vtec, then that wire will be able to be extended from the shock tower.
Old Feb 22, 2004 | 08:13 AM
the knock sensor if i am correct is browm was pulled out of the engine can it be replace or put back in?
Old Feb 22, 2004 | 08:35 AM
Mr Boston's Avatar
Buy another 94+ B series shift linkage
lude98SH
Sep 1, 2007 05:56 PM
sneakerfern
Jan 25, 2007 09:21 PM
importlegions
Sep 5, 2004 07:58 PM
Gir
11
Jul 9, 2003 09:12 AM
4g4me
Apr 22, 2002 09:23 AM
