CAR DIES out for no reason.......
can somebody please help me find a solution??
ok my car will start fine and run ok if i push the gas but wen i let off and the idle drops all the way to ZERO and turns off and then it starts fine again......
cleaned the iacv and tighten the fitv.....no vaccum leaks and tightened bolts to the TB.....map sensor is ok...TPS needs adjustment but it souldn't die.....
HELP
HELP
smokinloc
Mar 8, 2010 01:39 PM
