Looking for ideas on shedding weight off my car
Old Feb 16, 2004 | 10:35 PM
STHPERFORMANCE's Avatar
Default Looking for ideas on shedding weight off my car
I have a 91 Si hatch and i am wanting to get rid of dead weight......
So far i've came up with these ideas......
Remove all glass windows (instead of door windows) Replacing w/lexan
Remove power sunroof assembly
Remove everything from the front seats back (carpet,seats,panels ect..ect...)
Removing front and rear bumper supports
Is there a manufactor that makes Fiberglass rear hatchs ?
That would free up a decent amount of weight there.
Its gonna be street/strip car , Not daily driver so that why i choose the lexan idea and removing sunroof.
Also, Whats the easiest way to install a lexan front window, i would be buying the lexan from a local window place or home depot..
Old Feb 17, 2004 | 09:04 AM
kid-honda's Avatar
I put this in a post a few lines down.
Want to loose weight in a civic/crx
Loose the door impact beams and seatbelts for harnesses.
loose the heavy heavy stock seats.
get rid of or make custom or use hf front and rear metal bumpers.
sunroof plug.
ac
heater
keep all the plastics and look "full interior"
all the plastic in the car weighs less then the front seats.
BTW A PERFECT CIRCLE kicks *** A long time favorite of mine.
Old Feb 17, 2004 | 09:45 AM
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">I put this in a post a few lines down.
sunroof plug.
ac
heater
BTW A PERFECT CIRCLE kicks *** A long time favorite of mine.</TD></TR></TABLE>
Door impact beams, hmm, never thought of that one.
The seats are coming out, forgot to menchion that. Whats a good lightweight seat? Not looking for much bling in a seat so bride is out of the picture.. Sunroof will deffently be coming out for sure, i heard that free's up like 40+lbs? A/C crap is already out. Heater stuff unfortuntly is staying in the car.
Anyone familiar with Fiberglass rear hatchs? Also, trying to gain info on installation of lexan on front window. i seen some use a brace in the middle from the bottom to the top.
Modified by Crazyscott at 1:58 PM 2/17/2004
Old Feb 17, 2004 | 11:14 AM
kid-honda's Avatar
I am about to order sparco evo seats, real clean look and weigh about 14 pounds each, stockers are around 40.
Old Feb 17, 2004 | 05:27 PM
Big_Mike's Avatar
Default Re: (Crazyscott)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazyscott &raquo;</TD></TR><TR><TD CLASS="quote">Anyone familiar with Fiberglass rear hatchs?</TD></TR></TABLE>
MB Products makes a replacement fiberglass hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazyscott &raquo;</TD></TR><TR><TD CLASS="quote">Also, trying to gain info on installation of lexan on front window. i seen some use a brace in the middle from the bottom to top.</TD></TR></TABLE>
make a template out of the stock windshield and the brace in the middle is used mainly for support and to keep the lexan arched in the middle.
Old Feb 17, 2004 | 08:47 PM
bsracing's Avatar
Sounds good, but i wouldn't pull the door beams out with out a cage, and if you want to run most FWD classes you can't have lexan, also most states don't allow lexan for windshield on the street, just my .02
Old Feb 17, 2004 | 09:01 PM
Default Re: (bsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsracing &raquo;</TD></TR><TR><TD CLASS="quote">Sounds good, but i wouldn't pull the door beams out with out a cage, and if you want to run most FWD classes you can't have lexan, also most states don't allow lexan for windshield on the street, just my .02</TD></TR></TABLE>
There will be a cage installed, i wouldnt drive a car without door beams and it had no protection (cage).
I am not looking to race competition. Looking for a all out street machine. As for getting the car inspected with Lexan, I dont have to worry about that.
Old Feb 18, 2004 | 04:57 AM
Another Question -
What thickness lexan should i use for thr windows??
Old Feb 18, 2004 | 06:45 AM
phat51's Avatar
I would go with Percy's polycarbonate windows, its more scratch resistant and stronger then lexan, you can get 1/8in sheets through jegs high performance i know. http://www.jegs.com, look under window kits. and youd be suprised how many people take out the door beams without a cage.
Old Feb 18, 2004 | 07:43 AM
XLR8 GS-R's Avatar
Default Re: Looking for ideas on shedding weight off my car (Crazyscott)
about how much do the side impact beams weigh?
Old Feb 18, 2004 | 02:40 PM
Default Re: (phat51)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phat51 &raquo;</TD></TR><TR><TD CLASS="quote">I would go with Percy's polycarbonate windows, its more scratch resistant and stronger then lexan, you can get 1/8in sheets through jegs high performance i know. http://www.jegs.com, look under window kits. and youd be suprised how many people take out the door beams without a cage.</TD></TR></TABLE>
That is pretty cheap for complete uncut sheets...
40x72 Sheet is only $200.00 +s/h
phat00civic
12
Sep 29, 2011 05:28 PM
PhoebeusFenix
Mar 7, 2005 04:59 AM
trrbl1bmx
Aug 14, 2004 12:33 PM
STHPERFORMANCE
Sep 9, 2003 04:57 AM
aut0tek
Feb 8, 2003 11:57 PM
