electrical problem....need help please
Old Feb 16, 2004 | 08:18 PM
92siracer's Avatar
Default electrical problem....need help please
hey my sisters 01 civic is having a electrical problem ....the car dies like the battery when she drives at night. its basically when i turn on the lights. the gauges and everything cuts off and the car still runs...but itll cut off in a couple of minutes. we had the alternator and starter checked and they where good. i even bought a new battery.
thanks
Old Feb 16, 2004 | 08:27 PM
highcomp's Avatar
Default Re: electrical problem....need help please (92siracer)
any audio system or indiglo gages any thing aftermarket electricl lights, fogs, got to be something start there let me know
Old Feb 16, 2004 | 08:42 PM
92siracer's Avatar
Default Re: electrical problem....need help please (highcomp)
the car has nothing done to it......no system indiglos, or anything . bone stock . something is shorting or something i dont know....thanks
Old Feb 17, 2004 | 08:31 AM
92siracer's Avatar
ttt need help
Old Feb 17, 2004 | 12:19 PM
Perfectionist's Avatar
Plain and simple... you've got two basic systems involved.
First one is the battery. It provides the current to crank the starter and provide the electrical current to operate all the electrical stuff on the car.
The second is the alternator. It provides a recharge to the battery, and can help out when the draw is excessive.
If the battery is taking a crap, either its no good or isn't being recharged by the alternator. If its not getting recharged, check the alternator belt tension and the wiring from the alt to the main fuse block under the hood. If you have a voltmeter, measure the battery voltage (should be at least 12.4v). Start the engine and measure again while its running. (should be around 14v)
Make sure the dang battery posts connections are tight and clean, too.
Old Feb 17, 2004 | 07:11 PM
92siracer's Avatar
Default Re: electrical problem....need help please (Perfectionist)
koo thanks alot buddy!! imma go try it
Old Feb 17, 2004 | 07:53 PM
95swappedsi's Avatar
crank the car and take one terminal off if it keeps running u know alt is good......seems like one or the other though
Old Feb 18, 2004 | 06:44 PM
92siracer's Avatar
Default Re: (95swappedsi)
yeah i cranked da car and unplugged da positive and the car cut off.....but its koo though my sister is taking it to honda tomorrow...thanks a lot!
Old Feb 18, 2004 | 07:48 PM
boostn420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95swappedsi &raquo;</TD></TR><TR><TD CLASS="quote">crank the car and take one terminal off if it keeps running u know alt is good......seems like one or the other though</TD></TR></TABLE>
NEVER ever do that. It can create a current spike and short the ecu.
Johnoolo
Sep 16, 2013 05:15 AM
deanogreekareano
Nov 20, 2006 08:02 AM
Hesh
Dec 25, 2004 01:16 AM
imnotswapped
Feb 17, 2004 10:03 AM
crawdad689
Nov 21, 2003 11:35 PM
