Pics of my all motor crx engine...enjoy
Old Feb 16, 2004 | 07:12 PM
PearlCrx's Avatar
Default Pics of my all motor crx engine...enjoy
That is a properly build lsvtec I am tired of people putting it down...when I got the head it was full of calcium deposits , rust type of stuff...and etc....it was ported and polished out 3 angle valve job, notice the oil hole is plugged, it was welded and then resurfaced.....you can just put a stupid fitting in there and think it won't leak
Anyhow hereis the setup
lsvtec b18a1/b16a(pr3)
ported and polished head, 3 angle valve job, polished cumbustion chambers, deshrouded, titanium retainers, dual valve spring, cat cams race cams
Tapp Auto cam gears, skunk 2 manifold, FPR
Custom exhaust 2 1/4 with dynomax ultraflow, airmass header, knN filter
fuel is FPR , hondata, 510cc injectors.
civictype-r pistons, gs-r oil pump and water pump
I will post more pics soon. I made 190whp at 8300 rpms only the curve is still climbing but I rather not rev it too too high
Just wanted to say that if you build the lsvtec up and don't cheap out you can make a good engine rev to 8300 which is only 1100 more than stock ls....
No leaks , no missing, no backfires....nothing.....
and 12 somthing compression
food for thought
Old Feb 16, 2004 | 07:18 PM
EG8R's Avatar
Default Re: Pics of my all motor crx engine...enjoy (PearlCrx)
To doing it right.
Old Feb 16, 2004 | 07:20 PM
I Want An Si's Avatar
hrrm......isnt it the BLOCK that needs strengthening? granted all the stuff you have done is nice..... but without some sort of block reinforcing and/or Stronger Rods youre asking for trouble......
Old Feb 16, 2004 | 07:23 PM
PearlCrx's Avatar
Default Re: Pics of my all motor crx engine...enjoy (I Want An Si)
tons of the ls motors run 12psi on stock rods.
Old Feb 16, 2004 | 07:24 PM
^jefs0ng's Avatar
Banned
Looks pretty nice. Bottom end!
Old Feb 16, 2004 | 08:10 PM
Bee17hatch's Avatar
Default Re: (#jefs0ng)
thats nice man!
Old Feb 16, 2004 | 09:14 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Want An Si &raquo;</TD></TR><TR><TD CLASS="quote">hrrm......isnt it the BLOCK that needs strengthening? granted all the stuff you have done is nice..... but without some sort of block reinforcing and/or Stronger Rods youre asking for trouble......
Block is good
I dont know why everybody thinks the ls is so weak The B20 well that is cause its a bored b18 with thin walls.
The only weak point to a B18 would be the rod bolts and from what I hear something should be done aout the girdle(I am not for sure just what I heard).
And with no oil squirters a simple solution is forged pistons.
Old Feb 16, 2004 | 11:35 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Default Re: Pics of my all motor crx engine...enjoy (kid-honda)
i like the blue header
Old Feb 17, 2004 | 01:14 AM
payneth's Avatar
Default Re: Pics of my all motor crx engine...enjoy (iluvjasmine)
SHAWEET!!!
Old Feb 17, 2004 | 03:17 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Pics of my all motor crx engine...enjoy (OneSlowEF)
Damn that looks sweet, to a job done right the first time
Old Feb 17, 2004 | 05:25 AM
slow hatch's Avatar
Default Re: Pics of my all motor crx engine...enjoy (HybridHatch88)
looks killer. I'm digging that blue header
Old Feb 17, 2004 | 06:33 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PearlCrx &raquo;</TD></TR><TR><TD CLASS="quote">
yeah but they dont over-rev a stock block...
redline is what 6800 on the ls block not 8300, you should have gotten at least a girdle if you want to rev that high...
Old Feb 17, 2004 | 07:11 AM
99EKhatch's Avatar
2.25 exhaust on an all motor application? you should be running 2.5 to let that monster breath a little more
Old Feb 19, 2004 | 09:34 PM
Chronic_SMOKE's Avatar
damn i dont see why people are hating on this guys engine, i think its tight as **** just about every ls/vtec ive seen where i live hella leaks oil...good job
Old Feb 20, 2004 | 05:55 AM
crxgator's Avatar
Default Re: (Chronic_SMOKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronic_SMOKE &raquo;</TD></TR><TR><TD CLASS="quote">damn i dont see why people are hating on this guys engine, i think its tight as **** just about every ls/vtec ive seen where i live hella leaks oil...good job</TD></TR></TABLE>
dam s0n...n0 one be hatin on this engine y0...just using constructive critizimz ya heard...
Old Feb 20, 2004 | 06:09 AM
TragicLance's Avatar
You are my hero
wish i had the time/money to build
Old Feb 20, 2004 | 06:24 AM
PearlCrx's Avatar
Default Re: Pics of my all motor crx engine...enjoy (TragicLance)
thanks bro, get the b18a and later on pop hte vtec head on.....that is what I did I had a b18a swap for many years.
By the way I/H/E 15.4 to 15.2 and slicks I did 14.7 (with the b18a only)
Enjoy
Old Feb 20, 2004 | 06:28 AM
GEN2TEG's Avatar
Very sweet setup I gots love for the ls/vtec done right
Old Feb 20, 2004 | 06:29 AM
Jet Black's Avatar
Its not the block....there was an article about it somewhere on here...it has to do with the crank ratio beeing all off....a rev happy engine will have a smaller diameter crank....overrevving an engine with a larger diameter crank creates sidewall pressure in the block.
Not sure how _dangerous_ it is.
BTW Nice engine joel...you's better watch out for my winterbeater ya heard! The civic is missing at least 100lbs due to rust...so watch out
Old Feb 21, 2004 | 06:35 AM
jayjay's Avatar
Default Re: Pics of my all motor crx engine...enjoy (slow hatch)
I've seen that header before, they got the same style blue at Autozone for about
$219.00 I just bought one two days ago....................
A little Yellow and proud of it...............
Old Feb 21, 2004 | 07:11 AM
kleanlscivic's Avatar
nice *** setup man i am doing the same thing, have you ran it yet at a strip?
Old Feb 21, 2004 | 12:04 PM
no2psi's Avatar
Default Re: Pics of my all motor crx engine...enjoy (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">yeah but they dont over-rev a stock block...
redline is what 6800 on the ls block not 8300, you should have gotten at least a girdle if you want to rev that high...</TD></TR></TABLE>
Don't believe the hype. I have 2 of these motors spinning 9k all the time without problems. Stock rods, no oil squiters, no girdles. Stop reading and start building engines and you will know what works and what does'nt.
Old Feb 21, 2004 | 12:27 PM
bossman032's Avatar
Default Re: Pics of my all motor crx engine...enjoy (no2psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2psi &raquo;</TD></TR><TR><TD CLASS="quote">
Don't believe the hype. I have 2 of these motors spinning 9k all the time without problems. Stock rods, no oil squiters, no girdles. Stop reading and start building engines and you will know what works and what does'nt.</TD></TR></TABLE>
9k haha must me good to spin a ls that high
does it make power up their.. ??
Old Feb 21, 2004 | 12:45 PM
sohcvtec66
Guest
Posts: n/a
i like your avatar for some reason..lol
Old Feb 21, 2004 | 12:54 PM
no2psi's Avatar
Default Re: Pics of my all motor crx engine...enjoy (bossman032)
I only spin that high so that when I shift ,1st to 2nd. So that the rev drop puts me closer to peak power.
Peak power is 8400 rpm or so. Yea, to be honest "all day" is a stretch, but I wanted to get my point across.
