anyone know the name of this wrench?
Old Feb 16, 2004 | 06:47 PM
dfoxengr's Avatar
Default anyone know the name of this wrench?
ok its like a really old school drill, and the middle section is offset from the top and bottom(where the socket goes) and you hold the middle and top so you can spin the middle around which tightens or loosens the nut/bolt. and where can i get one. engine builders use these a lot.
Old Feb 16, 2004 | 07:41 PM
tSuperbike69's Avatar
Default Re: anyone know the name of this wrench? (hybridvteceg)
Sounds like you are talking about a speed wrench. Go to sears and as them to look at one and see if its what you need
Old Feb 16, 2004 | 07:56 PM
dfoxengr's Avatar
Default Re: anyone know the name of this wrench? (tSuperbike69)
that sounds familiar. thanks
Old Feb 16, 2004 | 08:02 PM
dfoxengr's Avatar
yeah thats it
Old Feb 16, 2004 | 08:18 PM
IN VTEC's Avatar
I've always wanted one, but I don't think I'd ever have much use for it. It's a little quicker on doing repetitive threadings, like cam plates, head bolts, main bolts, etc.
Old Feb 16, 2004 | 08:50 PM
-RedneckDave-'s Avatar
Working
I use one on a regular basis putting together pool tables and my boss calls it a hand crank, but that is from an old country man so i don't guess i know the technical name.
Old Feb 16, 2004 | 11:11 PM
simple4012's Avatar
New User
Default Re: anyone know the name of this wrench? (01accordv6)
i use it as the perfect spark plug wratchet
Old Feb 17, 2004 | 04:59 AM
JimBlake's Avatar
Default Re: anyone know the name of this wrench? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">... I don't think I'd ever have much use for it...</TD></TR></TABLE>You'd be surprised. I got mine for like $3 when a local hardware store went out of business. I used it for lug nuts before I got my impact wrench. Even now, there's lots of times when it's good for spinning nuts & bolts on. An impact wrench can bugger up threads too quickly for its own good.
Old Feb 17, 2004 | 09:29 AM
IN VTEC's Avatar
Default Re: anyone know the name of this wrench? (JimBlake)
$3 is a good buy. If only I were as lucky as you.
Until then...I'll just make due with a socket on an extension.
Old Feb 17, 2004 | 09:45 AM
BigLoadChoakHard's Avatar
there called speeders
Old Feb 17, 2004 | 09:56 AM
dfoxengr's Avatar
Default Re: anyone know the name of this wrench? (BigLoadChoakHard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigLoadChoakHard &raquo;</TD></TR><TR><TD CLASS="quote">there called speeders
thanks for the repeat.
motorhead_ls
Jun 23, 2006 03:28 PM
_Cyclone_
10
May 16, 2005 01:15 PM
SoOHiGH
Apr 27, 2005 07:29 PM
david90
Dec 2, 2003 06:42 AM
.jacob
31
Nov 12, 2003 05:00 PM
