y8 swap qeustion, will an auto y8 throttle body work on a standard intake manifold ??
running into some problems with teh wreckers
need to know if an auto y8 throttle body work on a standard intake manifold ??
Modified by BlackCRX at 2:50 PM 2/16/2004
Yes it will however, you will have to seal the two holes on the back side of the IM for the IACV.
Do you have an AUTO ECU?
if so, the auto ecu is going to look for the 3 wire IACV.
If you want to use the 2 wire IACV, then you need to change the pinouts at the ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">Do you have an AUTO ECU?
no i was able to get ahold of a p28 standard ecu pre socketed with a b16 eeprom
just gonna cut the jumper and run stock for now
Loyalhondahaver
18
Jul 16, 2024 11:38 PM
SOHC_Brian
Jan 15, 2004 08:57 AM
