oil stains on valve cover - need info
Ok i noticed oil stains appearing after i got the car...they are
appearing from the pcv valve opening also from the oil cap
... IS this serious? the car runs great! it just worries me a bit.
Modified by gray_ghost91 at 6:45 PM 2/16/2004
you should be able to replace the rubber seal around the pcv valve, as well as the hose...a simple replacement of your oil cap should "seal the problem"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">you should be able to replace the rubber seal around the pcv valve, as well as the hose...a simple replacement of your oil cap should "seal the problem"
...</TD></TR></TABLE>
wow....ive got the same problem....now i have an excuse to get a JDM oil filler cap j00......
...</TD></TR></TABLE>wow....ive got the same problem....now i have an excuse to get a JDM oil filler cap j00......
Takumi Fujiwara
Jan 31, 2006 07:52 AM
