Clutch Update -- I'm dropping my transmission. I NEED HELP.
Old Oct 10, 2001 | 09:24 AM
Phat Corolla's Avatar
New User
Default Clutch Update -- I'm dropping my transmission. I NEED HELP.
Well...I'm in the middle of dropping my transmission. Its a pretty time-consuming job. I am to the point of actually removing the motor mounts and taking the tranny off. However, I need help on removing one of the starter bolts. I can't seem to get a good enough angle to remove it. It is the one closest to the rear of the engine bay. Is there any good way of removing it?? I need to know by tomorrow night. Thank you.
Old Oct 10, 2001 | 01:30 PM
non-VTEC's Avatar
Default Re: Clutch Update -- I'm dropping my transmission. I NEED HELP. (Phat GS-R)
you might need a 6" extension with a wobble head and 12mm socket. you cant see it but you can feel it with your hands so you just have to feel where the head of the bolt is and get the socket on it. stick the ratchet way down the back side of the starter where you have plenty of room............
it's a long bolt to........
good luck
Old Oct 10, 2001 | 01:58 PM
New User
Default Re: Clutch Update -- I'm dropping my transmission. I NEED HELP. (non-VTEC)
see, that's the problem...I know where the bolt is. I just can't get a good enough angle to actually undo it. Would one of thos swivel heads for the ratchet work? (i'm assuming that's what was being refered to as "wobble head") Anyways, I'll give it a litte more work later tonight after my classes.
Old Oct 10, 2001 | 02:21 PM
non-VTEC's Avatar
the wobble head extension is just like a regular extension but the head where you attatch the socket to is not perfectly square. it's offset to give the socket some "flex" so you can work on slight angles........
even a flex joint adapter will work.......
Old Oct 10, 2001 | 02:22 PM
New User
All right, I'll give it a try. Thanks for the suggestion.
Old Oct 10, 2001 | 03:28 PM
miketegra's Avatar
It's just a matter of getting the right combo of socket, extension, and wratchet. I didn't use any special U-joint or other tricks.
Glad to see you doing it yourself. It's sick how much mechanics charge, and I'm sure you will do a better job because you actually care about the car - bravo !
Old Oct 10, 2001 | 03:54 PM
New User
Default Re: Clutch Update -- I'm dropping my transmission. I NEED HELP. (miketegra)
Yeah, I wanted a mechanic to diagnose the problem, so i took it somewhere to get an estimate. His estimate was $820 total. (parts/labor) Well..I get parts cheap, so it made no sense to have him do it. If i could just get that last damn bolt off...
Old Oct 11, 2001 | 05:46 PM
Import RP's Avatar
BUMMER, oh I got your clutch...I also picked up the crank seal, you will want to change that as long as your in there...I'll bring it by tonight..
Old Oct 11, 2001 | 05:57 PM
New User
Default Re: Clutch Update -- I'm dropping my transmission. I NEED HELP. (Pyrochaos38)
Dude!!! I just noticed your title!!!! That is frickin hilarious!!!!
Old Oct 11, 2001 | 06:05 PM
Mike95lude's Avatar
good luck guys
Old Oct 12, 2001 | 01:37 AM
New User
Default Re: Clutch Update -- I'm dropping my transmission. I NEED HELP. (Mike95lude)
Oh geez...That job was NOT fun. I am 99.999% done, so I'm turning in for the night. I can only hope I did everything correctly. Man, I'm worried...I can't wait to start it up tomorrow afternoon.
tensaiwung
27
Mar 28, 2012 10:02 AM
UserX826
10
Feb 21, 2009 10:02 PM
JohnWayne
Aug 3, 2005 07:10 PM
1994accordh22a3s
Jul 7, 2004 12:40 PM
nugget8000
Aug 23, 2001 11:04 AM
