can you run stock p28 on R?
Old Feb 15, 2004 | 07:16 PM
cjames235's Avatar
Default can you run stock p28 on R?
will the z6 program be sufficient for the R with a vafc? or should i not waste my time with the p28 if im not going to chip it? thanks
Old Feb 15, 2004 | 07:35 PM
PYITR821's Avatar
Default Re: can you run stock p28 on R? (cjames235)
no, it won't work....If you want to run a p28, the only way is to have it chipped and you still need a OBDII to OBDI conversion harness.
Old Feb 15, 2004 | 07:37 PM
darrinbrewer's Avatar
i would lean toward not using the p28 unless your gonna chip it, can the vafc change revlimit? because the p28 is no where near the redline a ITR would be happy at. i'm running a chipped p28 in my gsr with ITR cams/valvesprings/skunk2 manifold/jdm dc 4-1 2.5" collector header/tanabe cat back/cold air, instant message IH8RICERZ , he's ALL ABOUT p28's, he will aim you in the right direction.
i raced a gsr with a vafc, and rode in it, vtec was almost not even noticeable, and in my car, it has broke traction sometimes when 1st gear vtec kicks in..
Old Feb 15, 2004 | 07:40 PM
PYITR821's Avatar
Default Re: can you run stock p28 on R? (darrinbrewer)
yeah, PM IH8RICERZ...he can chip that p28 for you!!!! Great guy btw.
Old Feb 15, 2004 | 08:08 PM
cjames235's Avatar
Default Re: can you run stock p28 on R? (PYITR821)
hahahahaha oh yea i totally forgot about the damn rev limiter of the p28...... i need alot of punches in the head for that one..... anyways thanks for the help and ill im that guy about chipping
Old Feb 15, 2004 | 08:25 PM
and YOU WILL NEED a obd2 to 1 conv. harness as well, that is, if your car is 96+ which i'm sure it is
Old Feb 16, 2004 | 03:50 AM
cjames235's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darrinbrewer &raquo;</TD></TR><TR><TD CLASS="quote">and YOU WILL NEED a obd2 to 1 conv. harness as well, that is, if your car is 96+ which i'm sure it is</TD></TR></TABLE>
yea got that already, i make my own
Old Feb 16, 2004 | 10:17 AM
kenji's Avatar
25 Year Member
I have chipped p28s in stock and ready to ship for $160. Email me at kenji211@tampabay.rr.com for more info.
-kenji
Old Feb 16, 2004 | 10:39 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">will the z6 program be sufficient for the R with a vafc? or should i not waste my time with the p28 if im not going to chip it? thanks</TD></TR></TABLE>
What happened to the OEM ECU??
Old Feb 16, 2004 | 10:45 AM
iH8RICERZ's Avatar
thanks guys for the reference............ Please pm me if you would be interested
thanks
Jason
Old Feb 16, 2004 | 10:50 AM
metal-x's Avatar
Default Re: can you run stock p28 on R? (iH8RICERZ)
sorry for jumping off topic but I have a P28 ecu already chipped and I am using an OBD2 to OBD1 harness but my car won't start I have a 99 ITR btw....
any suggestions?
Old Feb 16, 2004 | 11:09 AM
iH8RICERZ's Avatar
Default Re: can you run stock p28 on R? (metal-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">sorry for jumping off topic but I have a P28 ecu already chipped and I am using an OBD2 to OBD1 harness but my car won't start I have a 99 ITR btw....
any suggestions?</TD></TR></TABLE>
will the car start with the stock ecu? or the car wont start in general?
Old Feb 16, 2004 | 11:18 AM
metal-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">
will the car start with the stock ecu? or the car wont start in general?</TD></TR></TABLE>
the car cranks but won't start up, but the car starts fine with the stock ECU
I've made sure the harness is plugged correctly
Old Feb 17, 2004 | 12:08 PM
jimsterli's Avatar
Default Re: can you run stock p28 on R? (kenji)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenji &raquo;</TD></TR><TR><TD CLASS="quote">I have chipped p28s in stock and ready to ship for $160. Email me at kenji211@tampabay.rr.com for more info.
-kenji</TD></TR></TABLE>
Do the chipped p28s have any problems running the o2 voltage? In other words, do they run closed loop with the stoich from the o2 sensor? I have had problems with my a/f (apex a/f meter) readings while running a chipped p28. The problem is resolved after swapping out the p28 for a non-chipped p28.
I'm in the market for another chipped p28 but have fears of my a/f ratio not showing up correctly on my meter.
Thanks.
redline23
May 7, 2004 06:10 AM
99B16Si
Feb 24, 2004 07:30 AM
CWESTINAP1
Jan 23, 2003 05:41 AM
