F22 fourth gen? anyone have any info
Old Feb 15, 2004 | 06:02 PM
phatrick2332's Avatar
Default F22 fourth gen? anyone have any info
I want to put an F22b1 into my hatch soon, and i was wondering if anyone has done it or if anyone has some info?
Old Feb 15, 2004 | 06:11 PM
GoFastMotorSports's Avatar
Default Re: F22 fourth gen? anyone have any info (phatrick2332)
Are you getting a good deal on one? I see no reason to put a f22 in a hatch. They are not a direct bolt in if I'm correct and would require some custom fabbing. I think a B or D series swap would be a better choice
Old Feb 15, 2004 | 06:26 PM
yes im getting a good deal, 50 bucks from my buddy, it needs rebuilt, but i would build anything that i put in. Plus i can get prelude parts for cheap cuz my cousin owns an import yard. h22 tranny for 100 bucks..i could buy the place racing weld in mounts for 300 but im just going to make mounts, thats no big deal.
the reason i want to is....147 horespower, and 148 ft lbs of torque...220 horespower is very doable with these engines, and if theres 220 hp..220 ft lbs of torque isnt far behind...which you kno that no honda engine makes torque like that.
Old Feb 15, 2004 | 06:29 PM
Default Re: (phatrick2332)
If you say you can get it in and its rebuilt,go for it, I have seen some F22's that were badass. Plus, a good hookup is always helpful
Old Feb 15, 2004 | 06:32 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">
and if theres 220 hp..220 ft lbs of torque isnt far behind</TD></TR></TABLE>
Not really. 220hp is do-able, but you'll need forced induction to realistically achieve more than 165 lb-ft or so of torque.
Old Feb 15, 2004 | 06:47 PM
well from all the accord forums ive been reading, if you do head work on the f22 so it will rev to 7k and a good cam, it makes that engine a beast, and then i want to do 11:1 compression and a good all around build..i think i could touch the 180-185 ft lb of torque area....and in a 1800 lb hatch...hehe
Old Feb 15, 2004 | 06:49 PM
f@sth@tch89's Avatar
Default Re: (Targa250R)
wouldn't the hasport mounts work for the h22...which im assuming is the same as the f22...if i could find the dohc vtec f22 prelude si motor...i would swap that one in my 89 std drag car...
good luck
Old Feb 15, 2004 | 06:50 PM
T S R Performance's Avatar
i really want to see how this comes out. never heard of it before but i know you can do some stuff to it. good luck bro
Old Feb 15, 2004 | 06:52 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (CivicHatchSOHC)
your going to need custom mounts, nobody makes a F series mount.
good luck
Old Feb 15, 2004 | 07:02 PM
Thats correct, the Hseries mounts would be exactly the same as the Fseries, so it would bolt right in with Hseries mounts...but place racing is the only one that makes them..and there weld in.
Mounts are the least of my worries, i have a parts car this is going to be all mached up on. Ill use the 90-93 accord intremediate shaft, and 91-93 teg axles along with the h22 tranny, and it should be a quick lil car, im hoping for 12s, which i think is reasonable with the amount of power i want to end up with. opinions on that?
Maybe when im done i can give a copy of my mounts to hasport or place to make bolt in kits for the F22
Old Feb 15, 2004 | 08:01 PM
SiB16A's Avatar
Default Re: (fasthatch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't the hasport mounts work for the h22...which im assuming is the same as the f22...if i could find the dohc vtec f22 prelude si motor...i would swap that one in my 89 std drag car...
good luck </TD></TR></TABLE>
Dohc vtec f22? there is no such thing...f22's are sohc's.
ive seen an f22 in a 92-95 hatch but never seen one in an 88-91 EF.
Old Feb 15, 2004 | 08:08 PM
Targa250R's Avatar
be professional
Default Re: (SiB16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16a &raquo;</TD></TR><TR><TD CLASS="quote">
Dohc vtec f22? there is no such thing...f22's are sohc's.</TD></TR></TABLE>
Right. He was probably thinking of the F20B from the JDM 6th-gen Accord SiR - which is basically a de-stroked H22A.
Old Feb 16, 2004 | 03:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Right. He was probably thinking of the F20B from the JDM 6th-gen Accord SiR - which is basically a de-stroked H22A.</TD></TR></TABLE> [URL]
http://www.hondaswap.com/forum...29825
check the honda engine list...its the f22b engine...dohc non-vtec that came prelude Si 92-96 not for sure this came in american cars..seems to be a good alternative powerplant
F22B 2156 160@6000 148@5000 9.2:1 85 95 dohc no 1 or 2 1992-1996 Prelude Si
Old Feb 16, 2004 | 08:00 AM
Eggman's Avatar
Doesn't Bisi have this done on his CRX? I heard he sells adapter plates that allow a D-series trans to bolt up to the F22 too.
Old Feb 16, 2004 | 12:17 PM
the adapter plates should be out next month...they have the adapter plate and a flywheel i believe..but im guessing it will cost some $
Old Feb 16, 2004 | 02:47 PM
f22sohc's Avatar
I am doing the same swap diff. car(crx) I am currently waiting for RS Machines to release there F/H motor d series tranny adapter kits. Hopefully they will be done early March. You get adapter, flywheel and engine mount for around $1350.00. Not bad considering what you are getting. Plus you have alot more gear ratios to play with. Good luck with your swap. F22's are going to become alot more popular do to there cost.
Old Feb 21, 2004 | 01:46 PM
Default Re: (f22sohc)
would an h22 head fit on the f22 non-vtec block? i know thats a rare motor to find. if not im considering the f20b(accord si-r) and use an h22 head.
bump for a good thread
Old Feb 21, 2004 | 01:52 PM
RuthlessEF-9's Avatar
Hey yo all power to you. Be different. Also go to D series.org ask Bisi for help
Old Feb 21, 2004 | 02:06 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 &raquo;</TD></TR><TR><TD CLASS="quote">im considering the f20b(accord si-r) and use an h22 head.</TD></TR></TABLE>
The F20B already has the same head as an H22A.
HOMEMADEPOWER
Jun 25, 2011 10:30 PM
rob_himself
Oct 24, 2007 07:04 AM
732xghost
Jul 12, 2007 01:51 PM
B-SerioUs EGg
Sep 12, 2005 08:02 PM
golf97
Feb 22, 2005 04:02 PM
