02 sensor in b18c into vx hatch
Old Feb 15, 2004 | 02:35 PM
EGhatched's Avatar
Default 02 sensor in b18c into vx hatch
okay i'm puting a b18c into a 92 vx. I'm using the vx harness. I got the knock sensor squared away, that was easy. How many wires is the gsr o2? It would be awsome if anyone has the colors and pin locations for the wires off of the b18c o2 sensor. I have another vx harness and I am semi building it until the motor comes in. like i said i know the knock goes to d3 .
Old Feb 15, 2004 | 04:23 PM
Hybrid96EK's Avatar
Default Re: 02 sensor in b18c into vx hatch (EGhatched)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatched &raquo;</TD></TR><TR><TD CLASS="quote">okay i'm puting a b18c into a 92 vx. I'm using the vx harness. I got the knock sensor squared away, that was easy. How many wires is the gsr o2? It would be awsome if anyone has the colors and pin locations for the wires off of the b18c o2 sensor. I have another vx harness and I am semi building it until the motor comes in. like i said i know the knock goes to d3 .</TD></TR></TABLE>
GSR uses the 4 wire O2. The VX was, to my knowledge, the only one that used a 5 wire and it was only in 92 and early early 93. If I recall right there is a white wire, a green wire, and two blacks. The two blacks are grounds, the white is the signal out, and the green is + v oltage for the heater.
Old Feb 15, 2004 | 07:47 PM
EGhatched's Avatar
Default Re: 02 sensor in b18c into vx hatch (Hybrid93Eg)
awesome! thanks!
WIZDOM
Mar 1, 2008 08:12 PM
Mentat Ghola
Oct 8, 2004 11:33 PM
H23vtecEG
May 18, 2003 05:36 AM
lowexr
Apr 17, 2003 02:48 PM
