Can i use 94up rear integra disc brakes on my 90 STD?
Old Feb 15, 2004 | 11:08 AM
1CiViC1's Avatar
Default Can i use 94up rear integra disc brakes on my 90 STD?
Ive gone thru searching but only found the 90-93 teg rear discs being used.
Will the 94up teg rear disc brakes work on my 90 std? TIA
Old Feb 15, 2004 | 11:42 AM
Mugen Dom's Avatar
Default Re: Can i use 94up rear integra disc brakes on my 90 STD? (1CiViC1)
yeh ull need the entire trailing arm ebrake cables and brake lines dont need to hook up the abs itll be there though....and uhhh yeh the civics will fit it also the EG and EK that it
Old Feb 15, 2004 | 04:03 PM
1CiViC1's Avatar
ok cool so the 94up cables will do right? i dont need to get the 90-93 cables?
Old Feb 15, 2004 | 05:56 PM
philly-O's Avatar
i think you need the 90-93 cables, and i recomend using the stainless steel lines when doing the swap.
Old Feb 15, 2004 | 06:55 PM
fffrog's Avatar
Default Re: Can i use 94up rear integra disc brakes on my 90 STD? (peichie)
94 cables work, but i would switch the two brackets that are on the cable to the original ones. you also need the brake hoses. If you mark were the compensator arm mounts you wont need to get an alignment.
nicky352
Dec 20, 2010 03:43 PM
honda_guy_07
Oct 21, 2009 04:08 PM
lrcrx90
Dec 8, 2007 08:16 AM
purple98ek
May 22, 2007 07:33 PM
stickywhiteEH2
Apr 15, 2004 09:03 AM
