5th gear grind
Old Feb 15, 2004 | 07:11 AM
DrewQ1's Avatar
Default 5th gear grind
I have a 94 and when i'm drivin hard or should I say when i shift at 5-6k rpms it grinds when i put it in 5th, but say i'm doing normal driving and not speeding it shifts into 5th with ease and no grind. Can anyone help me out on why its doing this?
Old Feb 15, 2004 | 04:51 PM
omeara7's Avatar
Default Re: 5th gear grind (DrewQ1)
I have the same problem on my 94' accord, but it grinds if i try to put it into 5th gear even at 3,000 rpm and above. I know this isn't helping you really but I have the same problem and I tried different transmission oils (like thin stuff 10w-30 and thicker stuff like sae 40). I was told that the syncro likes thicker tranny fluid but mine seems to grind a lot less when the transmission's hot.
Old Feb 15, 2004 | 04:55 PM
cd555's Avatar
Yeah you are shifting too hard. If you slam it into gear its not going to like it. Would you like it if someone were too jam your finger sideways? If you keep shifting like you do you wont have to worry about 5th gear or any other gear for that matter!
fw190bvi's Avatar
my 2nd gear gridns when its cold....but i think its the cold......apparently to check for a bad synchro, u drain trannny fluid and look for gold specs <-- gold = 'dying' synchro.....idk for sure, dont quote me on it
Old Feb 15, 2004 | 05:01 PM
omeara7's Avatar
Default Re: 5th gear grind (farroutt)
no, it grinds even when shifting in normal driving, like just casually going from 4th to 5th and i think it is my syncro b/c i did see some of that gold stuff in the drain pan. After driving for a long distance(like over an hour of highway driving) i can shift into 5th w/ no grinding at all so im pretty sure it's my syncro. Anyone know how much it is to replace?
Old Feb 15, 2004 | 05:04 PM
cd555's Avatar
Default Re: 5th gear grind (omeara7)
Sorry omeara7 I wasnt talking to you I was talking to DrewQ1.
Old Feb 15, 2004 | 09:44 PM
90Ninja
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omeara7 &raquo;</TD></TR><TR><TD CLASS="quote">no, it grinds even when shifting in normal driving, like just casually going from 4th to 5th and i think it is my syncro b/c i did see some of that gold stuff in the drain pan. After driving for a long distance(like over an hour of highway driving) i can shift into 5th w/ no grinding at all so im pretty sure it's my syncro. Anyone know how much it is to replace?</TD></TR></TABLE>
It's kind of expensive I've heard. And yes it is your 5th gear synchro. I wouldn't be driving it that hard anymore until you get it fixed or a new tranny.
Old Feb 16, 2004 | 03:26 AM
KGAccord's Avatar
Default Re: 5th gear grind (90Ninja)
when having grinding issues i would try first using honda mtl, then redline mtl, and then gm synchromesh. if those don't work then you got a problem.
Old Feb 16, 2004 | 12:13 PM
omeara7's Avatar
ok i'll try those different tranny fluids --thanks
94jdmlude
Dec 30, 2008 02:38 PM
jimmyrab
May 17, 2008 05:43 PM
Euro98ITR
Apr 14, 2005 09:40 PM
MTR.18
Mar 27, 2005 08:11 AM
