T3 turbo fit drag manifold?
Old Feb 14, 2004 | 11:12 PM
Bictorious's Avatar
Default T3 turbo fit drag manifold?
Will any t3 turbo fit a drag manifold?
Old Feb 15, 2004 | 01:39 AM
turbopimp's Avatar
Default Re: T3 turbo fit drag manifold? (Bictorious)
Yes, any turbo with a T3 turbine housing will work with the DRAG manifold.
Old Feb 15, 2004 | 02:42 AM
HybridKOOP's Avatar
Default Re: T3 turbo fit drag manifold? (turbopimp)
Block clearence is another issue.
Old Feb 15, 2004 | 06:20 PM
turbopimp's Avatar
Default Re: T3 turbo fit drag manifold? (HybridKOOP)
True, with a 4 bolt discharge housing there will be more grinding on the block to clear the compressor housing, especially if it is a T04e or T04s cover.
Old Feb 29, 2004 | 06:17 PM
Johnyquest's Avatar
You won't need to grind the block @ all with a straight t3 + a drag manifold-- if it's the same as it is for my D series, that is. Perfect fit.
Eklsv-t
Mar 14, 2008 07:04 AM
boost fed ls
Jul 27, 2003 09:07 AM
qwklude82
Mar 5, 2003 09:35 PM
turborex
Dec 20, 2002 02:43 PM
civicwagonman
Feb 22, 2002 06:31 AM
