how to hook up speedo after b series hydro install????
Old Feb 14, 2004 | 09:08 PM
allmotorgsrekk's Avatar
Default how to hook up speedo after b series hydro install????
like it says i need to know how to hook up the speedo in my hatch after putting b series hydro in?????? thanks noah
Old Feb 14, 2004 | 09:15 PM
EG8R's Avatar
Default Re: how to hook up speedo after b series hydro install???? (allmotorgsrekk)
Use the cable....
Old Feb 14, 2004 | 09:23 PM
Default Re: how to hook up speedo after b series hydro install???? (skelly ed6)
but do i need any thing from the old tranny that was in the car before ? (which would be a dx motor)
Old Feb 15, 2004 | 01:28 AM
Fobtions's Avatar
it should be the same thing if you are using the cable tranny, if u are hydro pull the electronic vss and stick the speedo cable assembly in
Old Feb 15, 2004 | 04:16 AM
REX VT's Avatar
You make make it work
Old Feb 15, 2004 | 05:14 AM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgsrekk &raquo;</TD></TR><TR><TD CLASS="quote">but do i need any thing from the old tranny that was in the car before ? (which would be a dx motor)</TD></TR></TABLE>
Yes, takeout the cable gear drive from your old tranny and put in the new tranny. You will not need the vss if you have cable speedo drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REX VT &raquo;</TD></TR><TR><TD CLASS="quote">You make make it work </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">it should be the same thing if you are using the cable tranny, if u are hydro pull the electronic vss and stick the speedo cable assembly in</TD></TR></TABLE>
It's really not a big deal, everything fits the same.
HTH
chris
Old Feb 15, 2004 | 03:24 PM
virginia_dude's Avatar
Default Re: how to hook up speedo after b series hydro install???? (NCchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">
HTH
chris</TD></TR></TABLE>
well he will need VSS if he has a Vtec motor, its a damn site chaper to use the Vtec ecu to switch it than an aftermarket alternative cobble job.
Old Feb 15, 2004 | 03:40 PM
NCchris's Avatar
Default Re: how to hook up speedo after b series hydro install???? (virginia_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">
well he will need VSS if he has a Vtec motor, its a damn site chaper to use the Vtec ecu to switch it than an aftermarket alternative cobble job.</TD></TR></TABLE>
Yup, you're correct. I have a B with vtec but it came that way. My CRX don't know about newfangle technology.
chris
Old Feb 15, 2004 | 05:28 PM
Jaker's Avatar
He doesn't need the VSS. The EF has a "speed pulser" built into the speedometer that will give the speed signal required for Vtec.
Old Feb 15, 2004 | 05:33 PM
keebler65's Avatar
Default Re: how to hook up speedo after b series hydro install???? (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">He doesn't need the VSS. The EF has a "speed pulser" built into the speedometer that will give the speed signal required for Vtec.</TD></TR></TABLE>
lol and what drives the speedometer? you made my day.
Old Feb 15, 2004 | 09:04 PM
Jaker's Avatar
Default Re: how to hook up speedo after b series hydro install???? (keebler65)
The stock steel speedometer cable.
Old Feb 17, 2004 | 09:27 AM
Simple, I have a working cluster, I have no speedometer cable. Its driven off the tansmission mounted VSS versus the Speedometer cluster based VSS., you don't HAVE to have a cable to have a speedometer. But if he wants Vtec to work he needs VSS , and needs it one way of the other, or he needs expensive alternatives to get it to work.
I bet he has a Cable type cluster but a JDM transmission that has a electronic VSS sending unit. If thats the case he needs to change it to a cable type drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">
lol and what drives the speedometer? you made my day.</TD></TR></TABLE>
Old Feb 17, 2004 | 10:44 AM
UK CIVIC B16A2's Avatar
I had the same problem, took me months to figure it out. dont ditch the vss, im 99% sure that its not just used for a v-tec signal. my car used to cut out at speed with it disconnected. u need to get yourself an aftermarket electronic speedometer and wire that in(i used a digital display rev-counter with a bit more resistivity on the counting circuit - complicated but cheap, i calibrated it by following my mates car on the mobile fone). you can remove the old speedo and place it there on a blanking plate(i know i did), or you could try and fit one from a later model but that seemed a bit too awkward and would probably mean a whole new cluster. plus a digital one looks really trick!
or you could put a cable gearbox in...
Old Feb 17, 2004 | 10:47 AM
thanks figured it out.
Aesthetic Gains
Jun 19, 2008 12:31 AM
DA_Boy_626
Aug 1, 2007 08:08 PM
Suck my DX
Apr 6, 2005 12:09 PM
g2lsv
Nov 22, 2004 10:52 AM
Jdmspooge
Jul 13, 2004 07:58 AM
