Will 90-91 Crx tail lights fit the 88-89 without any mods?
Old Feb 14, 2004 | 08:34 PM
b18crx's Avatar
Default Will 90-91 Crx tail lights fit the 88-89 without any mods?
Looking for some new tail lights(mine leak) and most out there for sale are 90-91....will they fit the 88-89?
thanks.
Old Feb 14, 2004 | 08:41 PM
kid-honda's Avatar
Yes they fit but if I remember you have to use the 88-89 tail harness.
The harness just plugs on and off real easy.
Old Feb 14, 2004 | 08:44 PM
b18crx's Avatar
Default Re: (kid-honda)
so just remove my harness and use on 90-91 tails? bolt patterns are the same? gaskets, etc?
Old Feb 14, 2004 | 08:47 PM
Fobtions's Avatar
Default Re: (b18crx)
yep they bolt up perfectly
Old Feb 14, 2004 | 08:49 PM
b18crx's Avatar
Default Re: (Fobtions)
thanks....ive noticed when people sell 90-, they only mention 90-91....nothing about the harness but now i know..
Old Feb 14, 2004 | 08:53 PM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">thanks....ive noticed when people sell 90-, they only mention 90-91....nothing about the harness but now i know..</TD></TR></TABLE>
They mention 90/91 cause 88/89 and 90/91 tails are different in appearence, the 90/91 tails have a darker center piece and a dark trim trace around the tails.
Old Feb 14, 2004 | 09:29 PM
y49crxsi's Avatar
Woah, that guy needs to modify his post, THe 90-91 tails use differenct plugs than the 88-89 tails. You need to get the plugs from a 90-91, from a junkyard or something, but otherewise the plugs wotn fit. They look much nicer imo, but yeah, need the plugs too.
Old Feb 14, 2004 | 09:42 PM
Fobtions's Avatar
Default Re: (y49crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y49crxsi &raquo;</TD></TR><TR><TD CLASS="quote">Woah, that guy needs to modify his post, THe 90-91 tails use differenct plugs than the 88-89 tails. You need to get the plugs from a 90-91, from a junkyard or something, but otherewise the plugs wotn fit. They look much nicer imo, but yeah, need the plugs too.</TD></TR></TABLE>
u need to edit your post , cause everything has been mentioned. He has a 88-89 so he is going to re-use his original tailight plugs.
Old Feb 14, 2004 | 09:46 PM
Origin's Avatar
yeah, why would you use 90 - 91 light harness on a 88 - 89. use your original harness from your car, just snap it on and plug it up. works everytime.
Old Feb 15, 2004 | 09:26 AM
b18crx's Avatar
Default Re: (Origin)
as long as there aren't any problems like leaks or off-center bolt patterns, im good...
i can deal with the harness i think.....incidentally, anyone selling some great condition OEM *88-91* crx tails? all mine are cracked and the gaskets are crumbling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">yeah, why would you use 90 - 91 light harness on a 88 - 89. use your original harness from your car, just snap it on and plug it up. works everytime.</TD></TR></TABLE>
Old Feb 15, 2004 | 05:22 PM
Origin's Avatar
try ebay. i always see them on there.
Old Feb 15, 2004 | 07:27 PM
Rywire's Avatar
Yeah, do this, I dont see why people say to swap harnesses. Ryan
Old Feb 15, 2004 | 11:17 PM
b18crx's Avatar
i've found like 10 sets(some jdm) and are viewing all of them....hopefully get a jdm set somewhat cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">try ebay. i always see them on there.</TD></TR></TABLE>
Old Feb 16, 2004 | 12:11 AM
B2FiNiTY's Avatar
Default Re: Will 90-91 Crx tail lights fit the 88-89 without any mods? (b18crx)
I've read both sides, some need to mod and some don't. So what is the straight story!?
Old Feb 16, 2004 | 04:36 AM
SETI20's Avatar
People get confused, because in europe and Japan we got a rear foglight.
Those harnesses are different.
Here in europe also the 88/91 harnesses are different, because the 88 style tails have 2 reverse lights, and a fog, and the 91 have 1 reverse light and1 fog.
Hope that clears something up.
Old Feb 16, 2004 | 09:31 AM
y49crxsi's Avatar
Default Re: (SETI20)
Hmm damn, ive heaed ti before, and some guy on hmt just posted he did the swap, but had to use the 90-91 plugs. I wonder what they were talkign about.
Old Feb 16, 2004 | 10:11 AM
crx-si's Avatar
I have it done on my crx, 90 taillights in a 89
all you have to do is use your harness from the 89 put it in the 90 taillights clips right in
no problem. and bolts up no problem the gaskets are the same also.
Old Feb 16, 2004 | 02:58 PM
B2FiNiTY's Avatar
Default Re: (crx-si)
So your basically saying this:
1) unbolt stock tails
2) bolt on 90-91 tails
3) plug it in and go?
Old Feb 16, 2004 | 07:52 PM
EF9 CiviC SiR's Avatar
yeah they plug up perfect i did it to my 88 crx and put 91 taillights
Old Feb 16, 2004 | 08:02 PM
Mr Furball's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">So your basically saying this:
3) plug it in and go? </TD></TR></TABLE>
Yes, You DO NOT NEED TO CHANGE THE HARNESS. It is plug and play. I have an 88 hf and I used 91 Taillights. PLUG & PLAY
I only have experience with USDM and JDM. European I am not sure about.
Old Feb 16, 2004 | 10:09 PM
crashtest Sonny's Avatar
Default Re: (Mr Furball)
the reason why you should use the 90-91 harness is because the 90-91 taillights uses 2 brake light bulbs whereas the 88-89 taillights only has 1. you can always find another socket for 1157 bulb and just solder it onto it. but with the 90 - 91 harness is much cleaner and easier.
Old Feb 17, 2004 | 03:50 AM
Mr Furball's Avatar
Default Re: (crashtest Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crashtest Sonny &raquo;</TD></TR><TR><TD CLASS="quote">the reason why you should use the 90-91 harness is because the 90-91 taillights uses 2 brake light bulbs whereas the 88-89 taillights only has 1. you can always find another socket for 1157 bulb and just solder it onto it. but with the 90 - 91 harness is much cleaner and easier.</TD></TR></TABLE>
Then why was mine plug and play. I did NOTHING to the harness. I have all lights working and all I did was bolt the lights too the car.
Does the HF have a SPECIAL harness
Old Feb 17, 2004 | 04:51 AM
Origin's Avatar
my 88 hf has two sets of bulbs for each side. then two reverse lights. and i have 90 to 91 si tails. everything was plug and play.
Old Feb 17, 2004 | 06:08 AM
opps..i was talking about the hatchback.
on me for not reading the title!
Old Feb 17, 2004 | 06:22 AM
88whitehf's Avatar
Some guys have got to do there home work damn. 88-89 plugs for the tailights are different then the 90 91. 90 91 they are a rectangle plug and on the 88 89 they are more of a square they dont plug right up. You would have to cut the clips off a junkyard car and wire them in just like y49crxsi said. oh and if you need 88 89 taillight's i have some from when i did my conversion. pm me if you are interested.
chris
