Please help idle stuck at 3000rpm
Old Feb 14, 2004 | 08:19 PM
Cburt24's Avatar
Default Please help idle stuck at 3000rpm
Hello eveyone i need some help with a B18c1 swap. The head was sent to Gude and had the full treatment then sent back to me and the engine was put back together and out of the blue the idle is now stayin at 3000 rpm's as soon as you start the car. I have had a couple different people look at the car and no one can figure it out any input would help.... Thanks
Old Feb 14, 2004 | 08:52 PM
Combustion Contraption's Avatar
check to see if you switched the map sensore and tps connectors.... very common and will cause that problem.
Old Feb 15, 2004 | 01:17 AM
Fobtions's Avatar
Default Re: (LsVtec92Hatch)
or it can be the throttle body needs to be adjusted. or a leak somewhere on the throttle body gasket, or intake manifold gasket
Old Feb 15, 2004 | 05:44 PM
DEVIN22CBR's Avatar
Default Re: Please help idle stuck at 3000rpm (Cburt24)
Have you checked yoru thotle cables tightness
Old Feb 20, 2004 | 02:38 PM
JBBNJ609's Avatar
i have the same problem with my GSR and i tryed all those things and no luck
cennouu
Mar 5, 2011 12:05 AM
SOHC_civic_si
16
Dec 29, 2010 02:25 PM
95dc2teg
Sep 11, 2007 05:49 PM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
TuCKiNaLL4s
Jun 21, 2004 08:31 AM
