h22 into 95 accord
Old Feb 14, 2004 | 08:16 PM
derekellison's Avatar
Default h22 into 95 accord
i have a 95 2d accord ex with a knocking motor and im wanting to replace the motor with a h22. and ive found a odb1 h22 motor only for $1000. what else would i need to make this work and is this a good price for a h22 keep in mind im on a low budget.
thanks to any replys
derek
Old Feb 15, 2004 | 12:18 AM
AsiAnVenOm's Avatar
p13 ecu and prelude driver side mount
Old Feb 15, 2004 | 05:34 AM
Default Re: (AsiAnVenOm)
so the tranny,axels, and wireing off my f22 will stay the same. what other ecu's will work. ive been told that there is 2 wires going into the ecu that will need to be switched. is this true and if so which ones are they. is
thanks for any help
Old Feb 15, 2004 | 05:08 PM
Slamaccord's Avatar
Default Re: (derekellison)
i believe the f series tranny won't bolt up to the h series and it would be a good idea to use prelude axles stronger don't want to snap them
Old Feb 15, 2004 | 05:14 PM
cd555's Avatar
check out http://www.h22a.org
Old Feb 15, 2004 | 05:43 PM
Nick H's Avatar
New User
Default Re: (Slamaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord &raquo;</TD></TR><TR><TD CLASS="quote">i believe the f series tranny won't bolt up to the h series and it would be a good idea to use prelude axles stronger don't want to snap them</TD></TR></TABLE>
f22 tranny will mate up to the h22...it's what i'm using currently...i am also you using the accord axles and haven't had a problem, yet....you will need to wire in a couple of things as well, mainly just the extra components of the h22 motor, like the iab's, etc...it's pretty straightforward though and is a good motor to wake up the accord, but don't expect mirracles out of it in stock form...
Old Feb 15, 2004 | 07:28 PM
sponger1054's Avatar
what you can use for the drivers site mount is a combo of the two....if you keep the prelude one on the motor and use the car side from the accord one bolt lines up...for the second one you can actually drill a hole in the motor side of the mount and put a bolt trhough it and a nut on top...it sounds a whole lot more ghetto than it actually is... also, youll need to make some sort of plate for the throttle cables to hold on to...just take a piece of scrap metal and cut and bend it in order for it to hold them...otherwise your goin nowhere....im actually using a prelude axle on the passenger side and the stock accord one on the drivers...i would recomend you use the h22 tranny though...the f22 works but ive driven both and the h22 is way more fun...i also had to buy the power steering bracket from an h22 prelude because the pump didnt line up in the 95 accord...but did in the 92 accord the motor was in...if i think of anything else about the swap ill add it later...good luck man...its a **** ton of fun
Old Feb 15, 2004 | 07:49 PM
Default Re: (sponger1054)
thanks for the info. i dont know if ime going to the h22 in right away im going to try to run accross a good deal on one first. the f22 is knocking pretty bad but i think it will be ok for a while. but when i decide to switch motors im defintely going with the h22. anyone know where i can get a h22 motor only for less than 1000 dollars. im going to leave the tranny and everything else i possibly can. im just looking for somthing to play around with.
Old Feb 16, 2004 | 09:33 AM
im not sure about what just the motor would cost but try http://www.hmotorsonline.com.. i got my full swap from them shipped for $2475 wich is really good. it came with evertying all the way up to the shifter and was in excellent condition...they do have just motors on the site...give it a look
Old Feb 16, 2004 | 09:37 AM
heres the link to just the h22a longblock...http://www.hmotorsonline.com/shop/sc...age&item=30026 not a bad deal....worth the extra 200 for the quality hmotors puts out
Old Feb 16, 2004 | 08:13 PM
thanks for the link the long block was $1200 plus shipping. ive found one for $1000 so if i can find one for less than that i would be doing good. what kind of ecu dose a 95 ex accord have and what will i need. could i get a parts list of everything i need to just put the h22 motor in. i dont wana change anything i dont have to.
thanks
Old Feb 16, 2004 | 08:55 PM
cd555's Avatar
Is your accord an auto or manual? If its an auto then you dont want to mate it up to the h22. If you do, I believe the transmission will shift as if its hooked up to the f22 and you wont ever see any rpm above 6000. I could be wrong about this but Im not sure. If you have a 5 speed disregard this post
Old Feb 16, 2004 | 10:26 PM
matix's Avatar
First of get a h22 with a h22 tranny. If you wanna make a trip http://www.raceup.com did my h22 swap into my 5th gen accord for 3gs said and done after taxes. They sell nice engines and put them in.
Old Feb 17, 2004 | 06:32 AM
Default Re: (matix)
i agree with matix...it really is worth the wait to do it right...you will love the full swap trust me
Old Feb 17, 2004 | 08:54 PM
Default Re: (matix)
like i said im doing this on a low budget with a pecking motor right now. im looking to put a motor in for as cheep as possible. if i want to i can get a tranny later but i just dont have the money right now and im needing a motor. i dont see any reason to put another f22 in my car when im planning on doing a h22 swap anyway. so i just need a motor right now. but maby later i will go all the way with it. and i will already have the motor i want.
Old Feb 17, 2004 | 09:09 PM
Luisito825's Avatar
ive had accord axles for 2 years now and ive had no problems.
Old Feb 17, 2004 | 09:38 PM
one clean ride's Avatar
hey is LSD worth the extra money? How big of a difference will it make?
Acura_DreamiN
May 12, 2009 07:01 PM
burplelude
Jun 9, 2006 10:40 AM
beaneg6
Aug 17, 2005 04:07 PM
c27_accord
Jul 26, 2005 05:51 PM
funkfnamna
May 6, 2004 11:08 AM
