fuel filter
Old Feb 14, 2004 | 06:41 PM
RUBZERK's Avatar
Default fuel filter
well, i have a 4th gen & i just have a few things that i should have done a while ago.
in the past 3 months i replaced my fromt 2 axles & rotors, breaks all around.
next is shocks & struts, lowering springs.
now how hard is it to replace the fuel filter ???
Old Feb 14, 2004 | 06:54 PM
Mike813's Avatar
Default Re: fuel filter (RUBZERK)
for 5th gen its a pain in the ***, i bought the filter and paid a mechanic 30$'s to change it for me... but if you have time on your hand go for it! youll need upper + lower access to ur car...
Old Feb 14, 2004 | 08:10 PM
fknslmd's Avatar
im changing mine tomarrow on my 5th gen, motor is out so itll be cake
Old Feb 14, 2004 | 08:32 PM
RUBZERK's Avatar
Default Re: (fknslmd)
Well that dont help me
Old Feb 15, 2004 | 05:08 AM
Mike813's Avatar
Default Re: (RUBZERK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">Well that dont help me</TD></TR></TABLE>
Try to take out the brackets that hold the filter down and relocate it up more so itll be easier to access next time you wanan change it yourself... if i remember someone did a write up on it, just needed longer fuel lines and they adjusted it like 5-6 inches upwards thats all... gluck...
Old Feb 15, 2004 | 12:49 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">well, i have a 4th gen
now how hard is it to replace the fuel filter ??? </TD></TR></TABLE>
Easy
Old Feb 15, 2004 | 09:47 PM
90Ninja
Guest
Posts: n/a
Default Re: fuel filter (Chiovnidca)
It's pretty simple. It's on the firewall on the passenger side. One fuel line coming from the gas tank and one going out to the fuel rail. Undo both those lines and undo the filter bracket. Repeat steps in reverse order to replace.
Old Feb 16, 2004 | 04:51 AM
iakona's Avatar
Default Re: fuel filter (90Ninja)
eeerrrr, not in accord country. that bad boy is on the driver's side buried between the front subframe and the motor. and those with an H22, it's a PITA to get to.
Old Feb 16, 2004 | 12:35 PM
.bagged's Avatar
Default Re: fuel filter (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">eeerrrr, not in accord country. that bad boy is on the driver's side buried between the front subframe and the motor. and those with an H22, it's a PITA to get to.</TD></TR></TABLE>
Mine is on the pass. side..
Old Feb 16, 2004 | 01:33 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">eeerrrr, not in accord country. that bad boy is on the driver's side buried between the front subframe and the motor. </TD></TR></TABLE>
It's on the pass. side of the firewall on a 4th gen.
Old Feb 16, 2004 | 01:42 PM
ForceThis!'s Avatar
I want to be the one to congradulate Honda in giving them the Numb Nuts Award for 1994-1997. The sadistic freak who mapped out the location for the fuel filter on G5s needs to drawn and quarted.
Old Feb 16, 2004 | 02:02 PM
iakona's Avatar
/\ agreed.
and i stand corrected on the 4th gens. lucky b*stards...
Old Feb 16, 2004 | 02:32 PM
.bagged's Avatar
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">/\ agreed.
and i stand corrected on the 4th gens. lucky b*stards...</TD></TR></TABLE>
bowaaahhhh...
very polite of you
Old Feb 16, 2004 | 05:01 PM
90Ninja
Guest
Posts: n/a
Default Re: (bagged93accord)
My Honda knowledge serves me right again. Haha
Old Feb 16, 2004 | 10:25 PM
accordfreak's Avatar
Default Re: (90Ninja)
stupid honda... first they hide the fuel filter then they force you to drop the fuel tank if you want to change the fuel pump.. THEN they use a funky ECU that is useless for modifying.
Old Feb 17, 2004 | 04:39 AM
iakona's Avatar
ha!!! i'll agree with you there!
Old Feb 17, 2004 | 07:25 AM
ForceThis!'s Avatar
Default Re: (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote"> then they force you to drop the fuel tank if you want to change the fuel pump</TD></TR></TABLE>
word. wtf!
Old Feb 17, 2004 | 07:56 AM
vabchaccord's Avatar
Default Re: (ForceThis!)
Hey, anyone know for sure whether a 5th gen. needs to change the fuel filter at some interval? The Honda dealers are telling me this is a "lifetime" fuel filter, i.e. never needs to be changed. Is this true? I thought all fuel filters needed to be changed at regular intervals.
Old Feb 17, 2004 | 08:08 AM
RUBZERK's Avatar
Default Re: (vabchaccord)
If they are lifetime filters then y do they make replacements?
They R feeding u a load of BS.
Old Feb 17, 2004 | 08:15 AM
ForceThis!'s Avatar
because occasionally they do clog with gum etc, so they must be replaced, but if you use something like SI-1 on a regular basis, no, the filter really doesn't need to be changed. Cut one open from a wreck with more than 150k on it, you'd be surprised how clean it is.
Old Feb 17, 2004 | 08:41 AM
Mike813's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vabchaccord &raquo;</TD></TR><TR><TD CLASS="quote">Hey, anyone know for sure whether a 5th gen. needs to change the fuel filter at some interval? The Honda dealers are telling me this is a "lifetime" fuel filter, i.e. never needs to be changed. Is this true? I thought all fuel filters needed to be changed at regular intervals.</TD></TR></TABLE>
Haynes say 30k miles it (should) be changed, if you have poor mileage do it...
im only getting 250 and less if i use heat and all that and that ish sucks....
Old Feb 17, 2004 | 09:30 AM
iakona's Avatar
i think mine needs to be changed as well. 62k on the chassis and 350 miles to a tank on my H22.
Old Feb 17, 2004 | 12:46 PM
By the way, what is SI-1?
Old Feb 17, 2004 | 01:46 PM
ForceThis!'s Avatar
SI-1 is Redline's fuel system cleaner. I also use their oil, Water Wetter, and MTL.
Old Feb 17, 2004 | 03:57 PM
Daniel M.'s Avatar
I change my fuel filter evry 20/30.000km.
My last fiter I kept it for a little to long and at idle went up and down and some times I had some missfueling.
I changed my filter and my engine runs perfect now.
I also tried to put some injector cleaner but it was ok only for that fuel tank, as soon as I did fuel again, it goes back as before.
