noise after replacing clutch
Old Feb 14, 2004 | 03:13 PM
98GeeYes-Are's Avatar
Default noise after replacing clutch
I replaced my clutch and now I hear a noise. It sounds like something is spininng. However when I press my clutch, the noise goes away. When I let go of the clutch it comes back. Any ideas of what it may be?
Old Feb 14, 2004 | 03:45 PM
HatchBox's Avatar
Skoobie no more...
Default Re: noise after replacing clutch (98GeeYes-Are)
everything tightened to spec?
Old Feb 14, 2004 | 03:52 PM
Jays91DXhatch's Avatar
Default Re: noise after replacing clutch (Hybrid Hatchback)
Did you replace the throwout bearing?
Old Feb 14, 2004 | 03:56 PM
Kaan's Avatar
Loved
Community Favorite
Default Re: noise after replacing clutch (Jays91DXhatch)
if the noise happens in neutral (out of gear) and the clutch is off... its almost always the throwout bearing.
Old Feb 14, 2004 | 04:02 PM
Default Re: noise after replacing clutch (MMsportsRexSi)
Yeah, i replaced the throwout bearing, and the pilot bearing. Damn, I guess I have to go back in there and re-replace it...
Old Feb 14, 2004 | 04:03 PM
Fobtions's Avatar
did u remove the flywheel when u installed it??? if u did , then maybe the flywheel is loose.
Old Feb 14, 2004 | 11:15 PM
Default Re: noise after replacing clutch (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">did u remove the flywheel when u installed it??? if u did , then maybe the flywheel is loose.</TD></TR></TABLE>
Yeah i removed the flywheel, but i made sure it was torqued on there tight.
Speed94
Aug 7, 2008 06:17 AM
Mr.Luder
May 25, 2007 01:47 PM
azteggi
Apr 19, 2005 07:57 AM
d_mina
Feb 3, 2005 12:06 PM
selectivebeef
Jul 1, 2003 08:27 PM
