Time for a smog check
Currently have
JDM 4-1
Test Pipe
OBD1 conversion
AEM Camgears
AEM FPR
VAFC
I just reinstalled my stock Header,Cat and stock ECU
Will I need to detune the cam gears, FPR and VAFC or will it pass as is?
What is the stock Fuel Pressure?
Thanks
JDM 4-1
Test Pipe
OBD1 conversion
AEM Camgears
AEM FPR
VAFC
Thanks
when i had my R it wouldn't pass smog with the test pipe.
i had a spoon header, aem cai, and a test pipe.
I don't think anything will pass smog with a test pipe. my levels where a few times more than the limit.
good luck
good luck
Since you have stock cams in the engine, why not just turn the cam gears back to 0,0? And, make V-AFC default w/ no corrections. I will look in Helm's later and will get you the stock fuel pressure.
I have to go in by April, but I have a code 67, probably coming from a bad carsound. Not sure how strict things are here in Illinois but all I have is an intake, hytech header and exhaust, and a VAFC, which will be set to default anyways. Should pass with flying colors..I hope
Thanks for the help
I'll let you guys know how it goes, I want to drive the car a few days to clean all the dirt and cobwebs from the stock header and cat and get it tested on Thursday or wednesday
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack »</TD></TR><TR><TD CLASS="quote">Stock ITR fuel pressure is approx 57 psi</TD></TR></TABLE>
47-53 psi with the hose off, if I recall correctly.
South Bay Surfer
Dec 13, 2004 08:41 AM
cjames235
Feb 28, 2003 10:23 AM
HuGEN
Aug 27, 2002 08:02 AM
