Brake rotor...2 screws removal tips?
Old Feb 14, 2004 | 11:36 AM
subgeniusdude's Avatar
Default Brake rotor...2 screws removal tips?
I'm doing the front brakes and replacing the rotors...however,the 2 screws that hold the rotor on are being beotches...can I just drill them out?They don't serve a purpose once the wheel is installed,right?Any other tips on getting them off?They're soft and strip easily.Thanks in advance!
Old Feb 14, 2004 | 12:06 PM
Kaan's Avatar
Loved
Community Favorite
Default Re: Brake rotor...2 screws removal tips? (subgeniusdude)
screw driver... hit with BFH!
Old Feb 14, 2004 | 12:08 PM
Mr Furball's Avatar
You need this,
Go here to get it,
http://www.sears.com/sr/javasr...Tools
It costs 25.00 before tax. Those screws won't be any trouble at all.
Old Feb 14, 2004 | 12:12 PM
Tyson's Avatar
Default Re: Brake rotor...2 screws removal tips? (Mr Furball)
you can get em a lot cheaper on ebay, or from harbor freight. search for "impact driver" this is the proper method to remove the screws without stripping them.
another successful way is to use a chisel/screwdriver to tap into the outer edge of the screw and torque it out with a hammer.
Old Feb 14, 2004 | 12:14 PM
zCivic's Avatar
Default Re: Brake rotor...2 screws removal tips? (Tyson)
impact screwdriver mmmmm good......Thats my recomendation but if you've already stripped them beyond get a drill....all the do is hold the rotor on while the wheel and caliper are off.....
Old Feb 14, 2004 | 12:56 PM
TOR's Avatar
TOR
If you have to drill them out I'd use an "Easy out to go ahead and get the shank out of the hub. Honda put those screws in there for a reason. I know they are a pain sometimes but keeping the hat on the hub seems like a good idea to me.
Old Feb 14, 2004 | 01:02 PM
haggard hatch's Avatar
Default Re: Brake rotor...2 screws removal tips? (TOR)
impact driver i just did my brakes last week. the impact driver makes the job much simpler. you can get one at pep boys for $9.99
Old Feb 14, 2004 | 01:55 PM
Grease Monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Furball &raquo;</TD></TR><TR><TD CLASS="quote">You need this,
Go here to get it,
It costs 25.00 before tax. Those screws won't be any trouble at all. </TD></TR></TABLE>
Old Feb 14, 2004 | 01:59 PM
AgentJam's Avatar
Default Re: Brake rotor...2 screws removal tips? (Grease Monkey)
Yeah do it right...i stripped mine using a DeWalt drill with phillips bit and man did i learn my lesson. I was so paranoid when drilling out those screws...didn't want to have to get new hubs.
Vince
Old Feb 14, 2004 | 02:09 PM
Bob_Digi's Avatar
what i do is get a 1/4 socket and put the screw driver head thing on, then push in real hard wiht one hand and turn wiht the other works everytime
Old Feb 14, 2004 | 05:58 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">another successful way is to use a chisel/screwdriver to tap into the outer edge of the screw and torque it out with a hammer. </TD></TR></TABLE>
An air chisel works every time.
Old Feb 14, 2004 | 07:23 PM
crashtest Sonny's Avatar
Default Re: Brake rotor...2 screws removal tips? (2point2)
if you dont have that impact tool, get a philip screw driver and hammer the **** out of it!! it'll loosen the thread on the inside then you'll be able to unscrew it with your hand. ive done it plenty of times.
Old Feb 14, 2004 | 08:13 PM
JDMHatch101's Avatar
you can pick one of these up at any autoparts store for $20
Old Feb 14, 2004 | 08:19 PM
blueintegra90's Avatar
Default Re: Brake rotor...2 screws removal tips? (JDMHatch101)
once u get them out just leave them out they only use them to hold them on the assembly line.
Old Feb 15, 2004 | 02:21 PM
D16 madwoman's Avatar
Default Re: Brake rotor...2 screws removal tips? (blueintegra90)
I just got done stripping mine two pieces, and yes they are biotches!!! I just went to SEARS and got the EZ out stripped screw removal kit (as seen on tv ) It worked fairly well but now I have a screw that is completely bored out in the middle... finally it came loose though and im glad I got some extras...
SPARK NOTES: go to SEARS
Old Feb 15, 2004 | 02:26 PM
paRRRker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">you can get em a lot cheaper on ebay, or from harbor freight. search for "impact driver" this is the proper method to remove the screws without stripping them.
harbor freights impact drivers suck ****...dont get them...i broke both of the phillip heads off on one frekin screw...then borrowed a friends snap on one and it worked great
Old Feb 15, 2004 | 02:45 PM
FourthGenHatch's Avatar
I use the Craftsman Impact Driver. Just leave the screws out once you remove them, they really serve no purpose.
Old Feb 15, 2004 | 04:00 PM
importboi22's Avatar
Default Re: Brake rotor...2 screws removal tips? (FourthGenHatch)
drill out the head and tap the rotor back then remove the stubs with a pair of vise-grips
Old Feb 15, 2004 | 06:03 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subgeniusdude &raquo;</TD></TR><TR><TD CLASS="quote">
can I just drill them out?They don't serve a purpose once the wheel is installed,right?</TD></TR></TABLE>
Right. All they do is keep the rotor aligned, they don't actually hold it on - most domestic vehicles don't even use rotor screws.
I use an impact driver and a lot of PB-Blaster fluid to get mine out, because they're almost always rusted or seized. The screws are actually pretty hard - hard enough to break the tip off of an impact driver bit. Happened to me twice. All the technicians at the Honda dealership keep extra impact driver bits on hand because this is a common problem with these shitty rotor screws.
I use a little anti-seize compound on the threads when I reinstall them, so that they don't freeze up in there.
Old Feb 15, 2004 | 07:58 PM
b16_madman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">once you remove them, they really serve no purpose.</TD></TR></TABLE>
correctomundo
Old Feb 15, 2004 | 10:49 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
You need an Impact Screw Driver Autozone caries it
Old Feb 16, 2004 | 02:25 AM
94_HATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
An air chisel works every time. </TD></TR></TABLE>
Thats how i got my rotors off. They were beotches as well
Old Feb 16, 2004 | 10:49 AM
Default Re: Brake rotor...2 screws removal tips? (94_HATCH)
Well,finally got it done...3 came right off with a stubby philips,but one was seized so I chiseled into the edge with a flat screwdriver then used a hammer to turn it counter clockwise.The rest of the job went smooth...I just didn't put the rotor screws back on very tight.Thanks for all the tips and idea,I'm sure other people will be asking the same question!
Old Feb 18, 2004 | 06:40 AM
Muckman's Avatar
Moderator in Chief
Default Re: Brake rotor...2 screws removal tips? (B16_madman)
I couldnt get mine out I just drilled mine out. They are unnessecary. With the wheel and caliper installed they cant go anywhere.
Old Feb 18, 2004 | 07:27 AM
Limited S.L.I.P.'s Avatar
well on the gsr i had to drill out one or two of them, but if they arent striped its nothing a phillips screw driver and a swift hit with a hammer cant fix.
