Steps to Adjusting Cam Gears, OBDII
do i have to mess with the distributor before i can adjust the cam gears,and if so, can i adjust the exaust cam without having to do anything with the distributor, because the distributor is on the intake cam, not exaust. Please let me know. thanks
From: Formerly of SF moved to DFW and now back in SF, CA, USA
I didn't touch the distributor at all when I got my gears adjusted.
If you're nervous just check the timing when you're done.
