How should I be idling?
Old Feb 14, 2004 | 10:30 AM
clsmooth's Avatar
Default How should I be idling?
I recently installed an Air/Fuel gauge and a fuel pressure gauge. I set the psi to stock and I'm trying to play with the idle screw on the throttle body so that it idles at Stoich. without sounding like a have an air leak, and, at least, below 1000 rpm.
But it seems no matter what I do, it seems to idle 'rich'. Is this normal? Does everyone's Honda do that?
Old Feb 14, 2004 | 11:38 AM
Benskins's Avatar
Default Re: How should I be idling? (clsmooth)
when its cold the fast idle kicks it well over 1000 rps, about 14-1500 rpm, and then when that kicks off, mine will idle at about 950 rpm. just let it warm up for a minute and kick the gas rela quick and it should go down.
Old Feb 15, 2004 | 10:38 AM
clsmooth's Avatar
Default Re: How should I be idling? (Benskins)
I'll let the car warm up to operating temperature and adjust the screw until the gauge reads Stoich. But when I go for a drive and then wait at a red light, it'll dip into the rich band.
I shouldn't have to kick-it down, it's not carbed.
Old Feb 15, 2004 | 10:44 AM
HamiltonRex's Avatar
Thoese guages are totally inaccurate.
Take it to a dyno.
-Eric
Old Feb 15, 2004 | 11:06 AM
roadawg's Avatar
Default Re: How should I be idling? (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Thoese guages are totally inaccurate.
Take it to a dyno.
-Eric</TD></TR></TABLE>
Or get a wideband 02.
Old Feb 15, 2004 | 11:14 AM
X-Static's Avatar
ive always thought that they only read correctly at WOT..but i may be wrong
Old Feb 15, 2004 | 11:18 AM
Default Re: How should I be idling? (hybrid honda)
Dyno's use wideban 02's thats what i was trying to imply.
-Eric
tejb02
Classic Hondas
Oct 12, 2011 08:07 PM
jdmstreethatch
Oct 25, 2006 01:26 PM
eg92b16a2
Nov 29, 2004 09:50 AM
ATS*Mark
Oct 19, 2004 05:48 PM
clsmooth
Feb 14, 2004 02:12 PM
