Rear disc conversion?
Hey guys I have a couple of questions on rear disc swap.I purchased rear trailing arms from a 91 teg..However, the guy and the junk yard cut the emergency cables and the brake lines..Any suggestions on what I should do..Buy new ones or go to junk yard..?
Just remove the wire and small sensor. I used 94 integra trailing arms, brake cables and brake lines. Everything worked perfect. Just so you know you can parts from a newer integra also.
JDMCRX
Suspension & Brakes
Sep 11, 2012 06:49 AM
