Do you turbo guys upgrade your valvetrain?
Old Feb 14, 2004 | 07:34 AM
B18Redline's Avatar
Default Do you turbo guys upgrade your valvetrain?
I'm preparing for a turbo application in the future and want to know if it is worth my time and money to upgrade my valvetrain to handle higher revs?
It's going to be a GSR turbo.
If you do recommend upgrading, what valve springs and retainers?
Thanks for any help...
Old Feb 14, 2004 | 07:47 AM
El Robz One's Avatar
Default Re: Do you turbo guys upgrade your valvetrain? (Redline07)
I WOULD SAY JUST DEPENDS ON HOW HIGH U WANT TO REV UP.....I HAVE LS TURBO AND KEPT EVERYTHING STOCK AND REVED UP TO 7200......NOW....MY FRIENDS WITH STOCK GSR TURBO REV A LITTLE HIGHER...UP TO AROUND 8 GRAND OR SO WITH NO PROBLEM...I THINK ULL BE OK WITH STOCK VALVLETRAIN
Old Feb 14, 2004 | 07:50 AM
tilt's Avatar
i think that would be dependent on your turbo - when it tops off, and somewhat your cam's powerband.
Old Feb 14, 2004 | 07:57 AM
B18Redline's Avatar
Default Re: Do you turbo guys upgrade your valvetrain? (tilt)
Hmm...I see...so most people stop making power with GSR turboes around 8K?
Old Feb 14, 2004 | 08:00 AM
FlaN.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline07 &raquo;</TD></TR><TR><TD CLASS="quote">Hmm...I see...so most people stop making power with GSR turboes around 8K? </TD></TR></TABLE>
depends on where your turbo stops making power
Old Feb 14, 2004 | 09:00 AM
-iLLuZioN-B18C1's Avatar
there are plenty of gsr's making power way over 8k.
Old Feb 14, 2004 | 09:22 AM
B18Redline's Avatar
Default Re: Do you turbo guys upgrade your valvetrain? (-iLLuZioN-B18C1)
that's what I thought........so should I go ahead and upgradethe valvetrain??? I will either be going with a Drag or custom turbo w/hondata.....
Thanks!
Old Feb 14, 2004 | 09:24 AM
im not sure what turbo comes with the drag. but i got a t3/to4e and power will start to fall before 8k. so if you getting a turbo like that, i woulnt upgrade valvetrian.
Old Feb 14, 2004 | 09:57 AM
twkdCD595's Avatar
I would like to upgrade the valvetrain in my head cause I only rev to 6250 max, but the longer f series rod/ stroke ratio is gonna keep me below 7200 I think anyways.
GsrIntegra789
Jul 19, 2007 10:22 AM
Not_So_JDM
Jun 22, 2007 11:09 PM
AL ASPIRATED
May 7, 2004 11:28 AM
